Trading Area => Car Parts, bits For Sale & Wanted => Topic started by: Toledodude1973 on 28 December 2013, 20:51:51
Has anyone got a rear blind and motor assembly for my 2002 facelift elite, ive read on OOF that earlier blinds have different wiring connections, mine wouldnt move up so with persuasion i've also broken one of the rods,so do need the whole thing
Different plug, same wiring
thanks Rob , the one you had has been sold yes?
`fraid so
I have a Black blind and motor assembly complete ,but it is from a 1998 model so would need a little altering to work.
As advised the physical size of the blind and unit is the same however the motor is sligthly different in construction but are interchangeable and will fit into the parcel shelf opening .You would need to cut the plug off the wire from your original motor and then solder that to the wire on the replacement as they are a different shape, but wire colours are the same.
I think sometimes they require a slight re-tension once removed and refitted as they are quite fragile and don,t like being pulled about,however with care they work fine
Thanks for reply Amba i think ive sourced one in Ireland someone breaking whole car, if all goes wrong i will contact yourself thanks again for effort Paul
