Omega Help Area => Omega Electrical and Audio Help => Topic started by: minifreek on 14 January 2014, 20:21:36
On my Vectra B I fitted a total closure module, so when I deadlock the car it would close all open windows and the sunroof too... what Im wondering is, can it be transferred over onto my Omega....? If it can, would it be the same wires that are connected on the Vectra (my thinking is the colour of the wiring in GM cars is for generic.... i.e Brown for earth/chassis and red is permanent +12V and Black is switched ignition live)..... would it be at all posiible following the same colour codes from the Vectra over onto the Omega... and where would the central locking module be located.... its located behind the drivers footwell kick plate in the Vectra....
Any help most appreciated :)
Omega has this function already or is it model specific maybe :-\
When you lock the car with the fob, hold the button down - don't release straight away :y
I shall give that a try tomrrow.... :y
thanks for the reply, might save me some head scratching ;D
No bother :y
Not sure about your other audio / stereo queries though. It does seem that the Omega is unique in many respects :-X
You mean in the resurrected thread from last year...?
I'll sort it, I usually find a way :)
Yes, sorry. The switch from the Vec. Bose is the main issue obviously,
Bose and its incompatibility issues with everything is the reason Im removing it from my motor....
You can also do the same with the key in the door lock... just turn it to lock and hold it there.
Yep tries both ways for the total closure, works with holding the key and holding the lock button on the fob... The module I have is as soon as I deadlock the car it closes all open windows and the sunroof if that is open too.... basically a fire anf forget type of mod... which I prefer TBH.... I presume the central lpcking module for the Omega is behind the drivers kick panel...?
Yep
Happy days, i was just reading through the thread and noticed a lot of mistakes... me and my BIG fingers LOL
Thanks for the replies :)
