Chat Area => General Discussion Area => Topic started by: tunnie on 19 January 2014, 14:42:15
Title: Painting Garage Floor
Post by: tunnie on 19 January 2014, 14:42:15
Looking for anyone who has done this themselves, from what I can see some people just slap the paint down, others seal it first.
I want it to last, so going to seal it first. Now that appears to be just a PVA glue mix?
Stupid question time, we are talking about something like this:
http://www.screwfix.com/p/no-nonsense-pva-5ltr/57248 (http://www.screwfix.com/p/no-nonsense-pva-5ltr/57248)
Which is then mixed with water, to 50/50? - Some of the guides I've read, say it's like painting with milk!
So once sealed, onto the paint, this stuff gets shite reviews:
http://www.diy.com/nav/decor/paint-woodcare/specialist-paints/garage_floor_paint/Ronseal-Diamond-Hard-Garage-Floor-Paint-Slate-5L-10727853 (http://www.diy.com/nav/decor/paint-woodcare/specialist-paints/garage_floor_paint/Ronseal-Diamond-Hard-Garage-Floor-Paint-Slate-5L-10727853)
This stuff gets much better reviews:
http://www.screwfix.com/p/leyland-heavy-duty-floor-paint-frigate-grey-2-5ltr/86567 (http://www.screwfix.com/p/leyland-heavy-duty-floor-paint-frigate-grey-2-5ltr/86567)
Anyone used anything else? Couple of coats of that & job jobbed? :)
Title: Re: Painting Garage Floor
Post by: chrisgixer on 19 January 2014, 14:44:13
Depends how good the concrete is. If its constantly dusty I'd seal.
Just painted mine though. Although its carpeted as well, partly.
It will wear though, eventually.
Post by: tunnie on 19 January 2014, 14:48:16
Don't remember seeing a lot of dust on the viewing, but for the minimal cost, might as well seal it.
Understand it will wear, but want to give it the best chance
Post by: kevinp58 on 19 January 2014, 15:28:25
You are better off sealing and stabilizing it with PVA as said 50/50 is good get a named brand as some of the cheaper ones are already thin  ::) let it dry then apply paint.  :y done this to several garages and worshops and it has stayed put.  8) :y
Post by: Seth on 19 January 2014, 17:18:11
Have found all the Leyland paints to be excellent, tunnie lad.
That price is about right too, though obviously make sure that your suppliers have enough of your chosen colour in stock, as I think that the quoted coverage guide's a bit on the 'generous' side.
PVA on the floor surface first - personally, I'd go for a 75% PVA/25% water mix.
Empty the PVA into a bucket, add/mix the water and go for it with a large brush. When finished, wash-out the brush with water and use same for the paint when the floor's dried-out.
'Ave it ... ;)
Post by: JasonH on 19 January 2014, 17:23:01
I sealed mine then painted it. That was a couple of years ago and then you could get proper solvent based concrete sealer. I couldn't pour enough sealer on to my floor it just kept soaking it up. I think if I had put thick floor paint on it then it wouldn't had adhered properly without sealing the floor first.
Anyway 2 or 3 years later it's lasted pretty well but is starting to look a little shabby. I'll do it again in the summer (so it dries faster). I used the screwfix paint and it was fine.
Post by: tunnie on 19 January 2014, 18:11:10
Many thanks everyone :)
Confirmed my plan of attack, I was leaning to Leyland paint anyway, but to hear first hand it's good is a great relief.
Looking forward to attacking this, will post up some photos in around a month or so when I shall be attacking this :)
Post by: biggriffin on 19 January 2014, 19:09:52
Go to local diy shed and buy some tins of gloss that have been reduced. Brush floor, seal with a pva seal mix,then use cheap gloss paint  :y
Post by: redelitev6 on 19 January 2014, 19:52:22
 Take the manufactures coverage estimates with a VERY big pinch of salt ! always seal the concrete with a good PVA mix , if it's new concrete do a 25% pva to water mix let it dry and then do a 50/50 mix , if you can , try and hoover the floor before painting it , nothing worse than ending up with grit in the paint  , if you have a lot of paint it might be worth while to give the floor a primer coat of a thin paint/turps mix , I did with mine and it gave a very good base for the top coat , also remember some of these paints give off a very strong smell so make sure the garage is well ventilated . as has been mentioned it might be worth trying to paint it in the summer months as the warmth will dry it out quicker .
Post by: tunnie on 19 January 2014, 20:34:42
Thanks again for all the advice, sadly I'll have to paint it in the coming weeks. Otherwise it will be full of junk before long ::)
Post by: Gaffers on 19 January 2014, 21:43:04
What about epoxy paint?  Colour and sealant in one.
Post by: Andy B on 19 January 2014, 23:19:54
Don't paint yourself into a corner!  ::) ::) ::)
My 'tandem double garage' has an up & over door at the front & a pedestrian door at the rear. I set off painting mine at the back at painted towards the big up & over. When I'd almost finished I tried to open the up & over from the inside to find that SMBO had since returned & parked right up to the door ...... the door wouldn't open &  couldn't get out unless I walked over my nice newly painted door!!  ::) ::) ::) ::) No phone in pocket .... hadn't quite been invented yet & she couldn't hear me shouting. I could just about reach the fuse box so switched the lights on & off till she came looking to see WTF I was playing at!  ;D ;D ;D ;D ;D
When I did mine (I read the instructions afterwards & I should have let the paint down 50/50 with thinners for the first coat  ???)
Post by: Vamps on 20 January 2014, 00:21:04
I remember those days, the freedom we had before mobile phones and emails........... :y :y
Post by: Ian_D on 20 January 2014, 00:40:09
 ;D ;D ;D Trust you Andy!  :y
Post by: Andy B on 20 January 2014, 09:32:16
Hiya Stranger ...... how's things?  :y  :y
Post by: slowboy on 20 January 2014, 10:54:32
mix varnish with floor paint.mines ok after 10 years
Post by: LC0112G on 20 January 2014, 13:00:09
One bit of advice from me.  Mix some coarse sand in with the paint before you apply it. When (yes when not if) you spill oil/water/PAS fluid/Diff fluid/Brake fluid on a smooth freshly painted floor it turns into an ice rink.
I did my garage floor about 3 years ago (PVA sealed and 2 part garage floor paint) and now, unless you're Torville or Dean it's virtually impossible to stand up in there.
Post by: LC0112G on 20 January 2014, 13:07:08
Ha - I started at the corner away from the door, and painted backwards towards it. Pleased as punch that I hadn't painted myself into a corner, I then went to go home. Couldn't find my car keys, then realised I'd hung them up on the wall - at the far side of the garage from the door. I managed to smooth out the footprints inside the garage, but there is now a row of grey paint footsteps from the garage door to where I park my car  :P
Post by: Andy B on 20 January 2014, 13:09:29
 ;D ;D ;D ;D ;D ;D ;D
