Omega Help Area => Omega General Help => Topic started by: Sir Tigger KC on 23 January 2014, 13:40:57
Title: Heater Matrix
Post by: Sir Tigger KC on 23 January 2014, 13:40:57
I think I've got a leak in my heater matrix as there is a slight smell of coolant when the blowers are on, although the carpet is dry.  :-\
I've read the guide on how to replace it but I'm wondering if anyone has tried pumping a strong radweld solution through it to stop up the leaks?  I was thinking along the lines of flushing the matrix, then throw a bottle of redweld or similar in a bucket and then pump it through the matrix.  :-\  The only downside that I can think of is creating enough pressure to get the radweld in the leaks.  :-\
Before anyone jumps on me, I'm NOT proposing putting radweld in the cooling system, just the heater matrix!  ;)
Title: Re: Heater Matrix
Post by: tigers_gonads on 23 January 2014, 13:50:31
Carpets dry  :-\
I'd be checking under the bonnet first around the HBV  ;)
If its a V6, its also possible the oil cooler plate leaking and the coolant is evaporating off the block with the heat of the engine.
Remember you are sucking the air into the car from underneath the bonnet  :)
Post by: RobG on 23 January 2014, 13:51:21
Radweld won`t just stay in the matrix due to it being part of the cooling/heating system ::)
Post by: Sir Tigger KC on 23 January 2014, 14:04:27
I know that!  :P I was thinking of disconnecting the matrix and pumping radweld directly through it.  ;)
Post by: Sir Tigger KC on 23 January 2014, 14:08:38
Carpets dry  :-\
New HBV!  :)
Oil cooler plate is possible so good point.  :y  At 215300 odd miles I'm considering changing the oil cooler before it gives up the ghost anyway, so that might be a good place to start.  :-\
Post by: tigers_gonads on 23 January 2014, 14:13:34
Carpets dry  :-\
New HBV!  :)
If you need some practice, get your arse up here and practice on mine  :y
I've been mopping white sludge out of mine with a old sock for the last month  ::)
Problem is, the sealant needs a good 24 hours to dry and I need it for hospital runs at the moment so can't take it off the road  :(
Post by: Sir Tigger KC on 23 January 2014, 23:15:34
After my travails with the alternator I'm taking a rest, but thanks for the offer Mr Gonads!  :)
Post by: dbug on 23 January 2014, 23:31:12
Easy solution - replace it mate - they're not expensive - just need to practice you keyhole surgery techniques ;)
Post by: tigers_gonads on 24 January 2014, 10:31:32
Par  ::)
About a hours work with a tea break  ;D ;D
Enjoy yeh rest  :y
Post by: Sir Tigger KC on 24 January 2014, 10:38:26
Hmm trouble is Mr Gonads has put doubts in my mind that it is the matrix now.  :-\  I don't want to go changing parts for the sake of it.  ::)
How about bypassing the matrix to see if the coolant smell goes.  :-\
Post by: tigers_gonads on 24 January 2014, 11:37:04
Might be a idea  ;)
If you remove the scuttle and plenum, it will give you a chance to look at the pipes back there too  :y
Also, if you have a spare coolant bottle cap, pop down the cycle shop or a tyre fitting place and scrounge an old shroader valve.
Drill a small hole in the top of the cap, pull it half way through and glue / seal it.
Then screw the new cap onto the expansion bottle and pressurise it a little with a bike / foot pump.
You will then see were the leak is  :y :y :y
