Chat Area => General Car Chat => Topic started by: 05omegav6 on 23 January 2014, 17:13:05
Title: Insignia Q
Post by: 05omegav6 on 23 January 2014, 17:13:05
Does the Insignia have an analogue speed signal?
If so where might it be located?
TIA, Al :y
Title: Re: Insignia Q
Post by: Auto Addict on 23 January 2014, 17:29:17
Yes, on the speedometer :y
Post by: 05omegav6 on 23 January 2014, 17:35:26
8)
Any idea which pin and on which plug :-\
Post by: Auto Addict on 23 January 2014, 17:41:50
8)
Correct ::)
Post by: 05omegav6 on 23 January 2014, 18:07:39
8)
Correct ::)
A touch ambiguous :-\
If I pop the cluster out, which wire do I tap into?
Post by: TheBoy on 23 January 2014, 18:21:04
I wouldn't mind guessing there is only CAN on the connector. Obviously at some point in the speedo, that gets converted.
Post by: 05omegav6 on 23 January 2014, 18:32:24
That has been suggested to be the case :-\ needed to drive a taxi meter, if I need to buy a box, so be it, hoping to avoid if at all possible :y
Post by: TheBoy on 23 January 2014, 18:42:02
Veccy-C only has CAN, can't see Insignia being different
Post by: 05omegav6 on 23 January 2014, 18:48:19
Not true :y has an analogue line but damned if I know what it connects ::) three BlRt wires near the heater motor, one of which is definitely analoge
Post by: TheBoy on 23 January 2014, 18:52:56
Did it change on later ones? As the half-CANs would have analogue for the HUs, for SDVC. Later Vecs had the full CAN HUs, so that analogue wouldn't be required.
Post by: 05omegav6 on 23 January 2014, 18:58:14
All 4 Vec Cs I've dealt with have had one, 3x '55 facelifts and one '58... :y
Have been advised a box is needed, but would prefer to fit the wiring myself...( Not that I'm precious about my cars or anything :D). ..if at all possible :-\
Post by: 05omegav6 on 23 January 2014, 19:04:03
Can pm reg if it helps :-\
Post by: TheBoy on 23 January 2014, 19:06:50
It wouldn't. :(
Can't think what a late vec-c would need analogue speed for, unless its a hangover from the half-can days
Post by: 05omegav6 on 23 January 2014, 19:09:03
VIN :-\
The Vecs were two Design models, one Exclusive and one Life... So no consistent reason I can think of either ;D
Post by: TheBoy on 23 January 2014, 19:12:19
VIN :-\
The wiring diags are generic, not filtered for a specific config/spec.  Not that I currently have access to Insignia Schems, as I'm, as usual, laying in the bath...
Post by: 05omegav6 on 23 January 2014, 19:14:58
 ;D you must get through more hot water than I do petrol...
Post by: TheBoy on 23 January 2014, 19:19:11
Don't tell my physio, as he goes radio rental, but I find it relieves my back.
Also, the steam at the moment loosens the flippin' snot I'm full of.
Post by: 05omegav6 on 23 January 2014, 19:20:33
That time of year again :'(
Post by: TheBoy on 23 January 2014, 19:30:21
Yeah, but 4 ****ing weeks, I'm bored of it now  >:(
Post by: 05omegav6 on 23 January 2014, 19:38:51
I'll bet :-\
Post by: I_want_an_Omega on 23 January 2014, 20:08:40
If it's of any help then the "analogue" signal that the ABS/TC module produces in the Omega isn't actually analogue at all. I STR that it's a 0 / +12v "square" wave that changes either frequency and/or mark/space ratio with speed. I scoped it once in a former life - but can't remember much more than that .......
I know for sure that it's a blue/red cable - on the Omega ..........
HTH
Post by: 05omegav6 on 23 January 2014, 20:11:44
That's the thing I'm seeking, if it exists, on the Insignia :y
Post by: Andy H on 23 January 2014, 22:22:03
I don't think you are going to find a speed pulse signal in your Insignia.
I think you are going to need one of these http://sailesmarketing.com/products/can-bus-interfaces/cb-1-canbus-interface/ (http://sailesmarketing.com/products/can-bus-interfaces/cb-1-canbus-interface/) to receive the speed data from the canbus and give you a speed pulse for the taximeter.
NB this isn't a recommendation for that particular manufacturer, just an illustration of the device you need (though of course they may be an excellent manufacturer :-\)
Post by: 05omegav6 on 23 January 2014, 22:30:44
 :y Easy enough to fit by the look of it... :-\
Post by: Marks DTM Calib on 24 January 2014, 08:30:50
So your looking for a digital speed signal, not an analogue one?
Post by: Marks DTM Calib on 24 January 2014, 09:14:03
To finish my input, you either need a converter such as a CANM8-PULSE (sub 50 notes) or you would have to tap into the ABS sensor input to the ABS ecu.
Post by: 05omegav6 on 24 January 2014, 10:29:53
The meter is a digitax f1. Whatever the Omega/Vectra C produces works, so looking for same on Insignia :y
Considering... http://www.connects2.co.uk/ProductInformation.aspx?id=10862&p=CTHVX02  (http://www.connects2.co.uk/ProductInformation.aspx?id=10862&p=CTHVX02)
As only has CD400, so swapping my current bluetooth headunit is a possibility...
