Chat Area => General Discussion Area => Topic started by: Mr Skrunts on 03 June 2008, 00:10:10
Spring is here so now is the time to check out your car air conditioner.
You could probably pick this tester up at most auto part retailers.
[size=16]How to check your car's Air Conditioner. [/size]
[size=14]1. Roll up all the windows.
2. Turn the AC on Hi. [/size]
(http://i278.photobucket.com/albums/kk106/skruntie/Air1.jpg)
[size=14]3. Put the tester in the car.[/size]
(http://i278.photobucket.com/albums/kk106/skruntie/Air2.jpg)
[size=14]Yup, it's working[/size]!
Admin, if this is against forum policy or offends any one then please delete.
god im in love,(http://emoticons4u.com/love/new/mrstraetz.gif)(http://emoticons4u.com/love/new/mrstraetz.gif)(http://emoticons4u.com/love/new/mrstraetz.gif)
not you skruntie ;D ;D ;D
She is beautiful :D
(http://i278.photobucket.com/albums/kk106/skruntie/99.jpg)
She is beautiful :D
absolutely stunning
my brother lives in columbia, you wanna see his g/f. latin lass, absolute knockout. he goes for a yr, comes back and sorts his houses out and business and money. then goes back, has done for yrs now
You could hang a wet donkey jacket on those ;D
Technically that will happen if on LOW, not HI, but hey ho ;D
Can you buy them from VX main dealers then ? any idea of part number.
Hey Skruntie this is one of your bettor efforts!
Impressed with your tech knowhow.
Where can i get one (or two) of these?
Ahh .. you've found the original model for Scammel wheelnuts ..... :y :y :y :y
;D ;D ;D
;D ;D ;D
Someone's rounded those ones off though. ;D
;D ;D ;D
Been "adjusted" / "tweaked" too many times ????
;D ;D
She could have somebody`s eye out with those! ;D
The manual said: Two pumps with the grease gun; but no-more, lest you 'blow the boots' ;D
I should be that lucky to get that close !!!!!!!!!!!!!
;D ;D ;D
Looks like feeding time with those!
Any small people in the car as well ;D
:o :o :o :o
i have the vaux part number for the air con tester !
send £5,000 to me and ill send you one.
small print.
the tester you receive may not be the same colour, size or shape as the one advertised in the picture. ;D
Is that on a Trade Card then ? seems a bit pricey as I have seen them down here for much less but probably second hand parts then.
the ones i have are poor copies im afraid!
Yeah, this is one item where I can imagine the quality of pattern parts is a bit "variable". ;D
Don't forget. As always, a squirt of plus gas and it won't be as easy to strip them. :-X
:o :o :o :o :o :o :o :o :o :o :o
I have heard f the term "smuggling peanuts" but that's taking the biscuit :o
chapel hat pegs. :D ;D
She is beautiful :D
she's also photoshopped, meaning her own bullets are potentially more impressive ;D
She is beautiful :D
I see you have studied her in great detail there Danny. ;D ;D ;D :y
As a matter of interest what should be the temp coming out of the Air vents on the Climate when set to Lo?
TIA :y
It depends on ambient temperature but, IIRC, with the fan flat out at nominal "English" ambient temperature after a running with the doors open for a while to get the system going the spec is 5 - 10 degrees C.
