Omega Help Area => Omega General Help => Topic started by: Kate on 02 February 2014, 15:36:29
Can anyone help me identify the part I'm looking for? I need an ABS ECU for my 2000 3.0 Auto.
I found this on Ebay.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=331120519887&ssPageName=ADME:X:RTQ:GB:1123 (http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=331120519887&ssPageName=ADME:X:RTQ:GB:1123)
Looking at the picture, is the ECU present?
Thanks so much. :y
Ecu is the black plastic bit on the front.
Ecu is there.
you need to check your part number is the same.
The part is on the car so I can't find the number.
This is an Abs pump that has been removed from my 1996 Manual Vauxhall Omega 3.0 ltr V6 Petrol Elite. It is a Bosch pump and is numbered 0265303002.
Is this the same number as yours?
I see his is a manual and yours is an auto, I don't know if this makes a difference, I will have a look around and see if I can find out
Thanks very much. :y
I pre 1998 v6 ECU is not suitable for a post 1998 v6
Thanks TB. :y
What about this one?
What year is yours, as that say 1996. Pre 1998 ECUs are reliable, but incompatible with later cars.
Kate.
It would be worth your while,and save you alot of grief,if you can either remove the faulty abs unit,or get somebody else to do so.Then send it off for a refurb at say BBA Remain in Rochester as they will do a full refurb on it and give it a warranty.Allyou thyen need to do is refit it and it will be sorted.
IMHO I think that would be a safer option and alot quicker.It should cost sub £130 and obviously a few £,s to have it removed/refited if you don,t fancy the job.I would happily pick the old unit up from you as in Caterham Tuesday evening and could drop it off at BBA Wednesday morning as I live just round the corner from them .They refurbished mine on my old 98.2.5 several years ago and I know others have used them to.
Pm if you need any help,but I did struggle removing mine so its not a job I would be looking to take on again
if you send PM to robseymv6 sure hi will supply one :y
Kate.
Thanks very much, that's very kind of you. :y
Getting the part off is the problem as I'm almost useless my self and there's no-one near to help.
What would be useful to know is whether the car is still usable with the ABS ECU removed? If so, I could take it somewhere to get removed.
I'll be in touch if I can get the little bugger out of the car! :y
Thanks again. :y
Thanks Serek, I'll send him a message. :y
Car can be driven without it :y after all you all ready have no speedo or abs ::)
Be sure that whoever removes it covers the abs unit with a bag to keep the water off until you get it back :y
Thanks Al. :y
Kate.
I drove mine for a few weeks with old one removed,but as said,you must waterproof the exposed end as the pump will get muck/dirt inside the system.
It is a fiddly job removing and refitting as space is very restricted and the little bolts are almost out of sight but patience and it can be done with a selection of flexy shafts and torque keys.
Give it a go ,after reading the excellent write up on it in the maintenence section.
Kate.
I paid a garage £65 to remove my ABS ECU and refit it once it had been repaired by BBA Reman, and judging by what others here have said about the job and what a PITA it is, I think it was money well spent! :y
So I second what Amba says here and I recommend getting yours fixed by BBA Reman as it's still fine 5 years on! :y
Edit: It might cost a bit more than £65 these days though..... ::)
Something else new learned today. Thanks TB :y
There are a few different par numbers, 3.0 auto is really hard to get hold of you are better sending yours off for repair (I was in the same position and waited over 12 months never found a 2nd hand ABS ecu with the same part number as my 3.0 elite - 0273004207.
BBA reman have recently put their prices up and now want £200 for doing an Omega ABS ecu which is too much, you are better off using ECU Testing ltd - they still charge £100 plus £30 collect and deliver
Telephone: 01773 535638
(If calling from outside the UK dial: ++441773535638)
Address:
ECU Testing LTD.
Unit 7, Slack Lane
Heanor Gate Ind Est.
Heanor
Derbyshire
DE75 7GX
OK to drive (no different to now when the lights are on). Just remember, no abs, no traction control, no speedo, no speed sensitive steering etc
Thanks for all the advice! :y
It would be great to send the part away and get it fixed but funds are very tight due to unemployment. I'm trying to get the car sorted as cheaply as possible which isn't ideal I know, but I've got no choice.
The car is driving fine apart from a noisy wheel bearing. I've driven some shocking cars in my time so not having abs or traction control isn't a problem.
About 3 years ago I had a 1955 Austin A30 and whilst driving the brakes completely failed. This turned out to be of the most scarey experiences of my life. :o :o :o
I was driving up Houghton Cut, a steep A road in the north east, when the engine lost power and the car started to roll backwards. Then gearstick came off in my hand and the handbrake didn't work!
http://www.youtube.com/watch?v=bZkpwlG8dWo (http://www.youtube.com/watch?v=bZkpwlG8dWo)
And no insurance if involved in a bump and someone spots it ::)
