Omega Help Area => Omega General Help => Topic started by: Shackeng on 02 February 2014, 20:21:16
(http://i1119.photobucket.com/albums/k631/Shackeng1/002-1.jpg) (http://s1119.photobucket.com/user/Shackeng1/media/002-1.jpg.html)
While sorting out some rusty brake pipes, I found this hiding under the body seal in the NS inner rear wing! It will, I think, require a plate welding in, as it is almost through to the inside. Is this a common rust area?
I Had to repair mine in the same place but mine was a lot worse and my old one was the same . I'd say it was a common area to go. Check under the cover at the end of the sill too!
Yep under the rear sill cover is very common, both mine and my dad's are going there and I believe linked to that very same issue??
Is this an MOT failure?
Any experts on MOT's here?
From the pic I would say yes as its within 30cm of the spring mount. When you clean it I can almost guarantee it will go through.
Also remove the side bolster and check the floor by the seat belt mount as it spreads a lot further than it looks..
can confirm what Lee4206 says would fail an mot
Thanks very much guys, I'll get it fixed. :y :y :y
