Omega Help Area => Omega General Help => Topic started by: JamesV6CDX on 04 February 2014, 11:13:52
Title: Damaged rim?
Post by: JamesV6CDX on 04 February 2014, 11:13:52
Driving on the m1. Felt a vibration through whole car, felt just like a misfire. Drove for maybe 6 miles intending to stop in nearby services and check it out
Before I got there, did a lane change, and, whooaa.. That vibration is a rear flat tyre!!!
I pumped it up to get me off the motorway and it felt like I had an egg for a tyre
Million dollar question - will it be just the tyre shagged, (it clearly is) or shall I not trust the wheel either now? It looks ok, but.... :/
Title: Re: Damaged rim?
Post by: chrisgixer on 04 February 2014, 11:35:44
You'll have to put the spare on anyway, no?
Post by: JamesV6CDX on 04 February 2014, 11:44:02
Oh I did to get car home
Just concerned if the alloy will be ok with a new tyre or if its likely to be buckled..
Post by: Andy B on 04 February 2014, 11:48:43
Million dollar question -  .....
is surely  ...... how did you drive for 6 miles on a flat & not know?!?!?  ???  ???  ???
There's no reason that the rim will buckle by driving on a flat tyre, it's just the possibility of grinding the lip of the rim away. If there's no obvious damage to the rim, I'd say you just need a new tyre (and a TPMS  ::) )
The wife of a  a lad at work arrived home one day & said there's something not right with the car .... it's making an odd noise & the handling isn't right. She'd driven on a flat (at the back) to the point that the tyre was virtually none existent and she'd been effectively driving on the rim. The rim was a write off.  :o :o :o
Post by: JamesV6CDX on 04 February 2014, 12:22:32
Thanks andy, the tyre stayed intact and the rim looks untouched :y
Post by: Andy B on 04 February 2014, 12:39:12
The steel belt in the tyre worked then  :y :y
Post by: henryd on 04 February 2014, 12:39:46
If it looks ok it probably is,get the tyre boys to check its still round and true when they balance the new one :y
Post by: zirk on 04 February 2014, 12:42:38
What He said,  :y a good inspection, should be fine, if any grit marks around the rim just flaten down.  ;)
