Chat Area => General Car Chat => Topic started by: JamesV6CDX on 10 February 2014, 21:18:14
Title: Best source of dexron 3
Post by: JamesV6CDX on 10 February 2014, 21:18:14
Need some for an ar35 swap on Wednesday...
Thinking may have to be locally - euro car tards?
Not worried on make as long as it meets spec :y
Title: Re: Best source of dexron 3
Post by: JamesV6CDX on 10 February 2014, 21:19:04
Also, I've totally forgotten how much ATF it takes!! 8l?
Post by: JamesV6CDX on 10 February 2014, 21:20:10
Last but not least do we have a step by step picture guide for an auto box swap? If not I will do one :y
Post by: pauls on 10 February 2014, 22:09:24
James
 I know somebody will come along with he correct amount but when we did mine didnt we use nearly 9lts
Post by: Bigron on 10 February 2014, 22:14:59
I bought this - is it a good price?
www.ebay.co.uk/itm/290994733693?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Ron.
Post by: Shackeng on 10 February 2014, 22:29:58
Check VX on TC James, last year 20L was £42.95. :y
Post by: Webby the Bear on 10 February 2014, 22:42:55
I used Carlube for my top up. if that helps :)
Post by: Kevin Wood on 10 February 2014, 22:44:35
If the torque converter starts off empty you probably want 10 litres to be on the safe side. Pauls' 9 litres is about on the money, I reckon.
Post by: chrisgixer on 10 February 2014, 23:01:37
Two 5 litre cans covers it.
Fuchs Titan via google. :)
Post by: biggriffin on 11 February 2014, 08:25:27
Get a cheap pressure fence sprayer to fill said box, from memory with empty torque conveter takes 9L.
are you going to drop sumps before fitting and clean, filter can be washed with petrol.
Removal. Unbolt prop, remove down pipes,un plug lamdas,unplug gear box lectric plugsx2, remove cooler pipes and allow to drain,remove inspection cover bung to allow acess to flex plate,torque converter bolts.
Haynes is helpfull,can be a bit ott tho..
 done a few its easier on a ramp with a gearbox lift,or a friend. Bit of a pain on your back on axle stands,again do able just takes bit longer,  enjoy :)
Post by: JamesV6CDX on 11 February 2014, 08:57:50
Nope. The filters never clog. I'm going to hold it upright (prop end down), remove the sensor right at the bottom, and allow the contents to empty into a bucket.
That way I save time and money with new gaskets on the sumps. I hate used ATF.
Post by: biggriffin on 11 February 2014, 10:17:03
Guessing its your own car then ::)
Post by: JamesV6CDX on 11 February 2014, 10:44:05
Yes. If it was for someone else I would remove sumps and filter as advertised
In reality it's pointless.
I learnt this trick from sassanach. What he doesn't know about these boxes isn't worth knowing.
Post by: Kevin Wood on 11 February 2014, 12:03:54
Depends how much crud there is in the sumps to get flushed back into the bearings and clutches. I think, on a gearbox not known to me, I'd have the sumps off at least the first time. :-\
Post by: JamesV6CDX on 11 February 2014, 12:33:20
I couldn't help myself
I've drained the box and removed both sumps
No crud as such, but some satisfaction had by wiping out the sump pans :D
I have got exactly 6 litres out of the box,
Anyone know how much the T Converter holds? :y
Post by: JamesV6CDX on 11 February 2014, 12:35:37
Oh, vx wanted £100 for ten litres of ATF, I bought D3 from euro parts for £60
Picked up a 20 l drum of semi synth for the engine while at vx tho :y
Post by: 05omegav6 on 11 February 2014, 12:35:51
Probably 3 or so litres ::)
Post by: JamesV6CDX on 11 February 2014, 12:44:06
I was guessing more like 1 litre, and a litre in the cooler? Just guesses though
Post by: Kevin Wood on 11 February 2014, 12:44:40
Yep, I have a recollection that in total it's about 9 litres, and about 7 required for a quick change (i.e. excluding any fluid in the TC and cooler plumbing, less spillages, the amount required to establish the traditional Dex-3 hairdo, etc.).
Post by: Shackeng on 11 February 2014, 15:08:27
 :o :o :o
Just checked with my local VX, still £42.95 for 20 litres  on TC. :y
Post by: Kevin Wood on 11 February 2014, 15:19:01
 :o :o :o
That's probably the usual nonsense in that they only stock 1L bottles "sealed for life, don't you know"*.
* - Where Life = 80K miles
Post by: JamesV6CDX on 11 February 2014, 16:21:20
 :o :o :o
Are you certain that is ATF?
I paid that today for 20l engine oil on TC..
Post by: Shackeng on 11 February 2014, 17:19:15
 :o :o :o
Yup. ATF Dexron 111 semi-synthetic 20 litres. Their code : UKTOGA06.
In both my gearboxes.
The 10W-40 engine semi-skimmed oil is £27.95  20 litres. :y
All on TC and plus VAT. :y
These are the same prices as last year, so quite a good deal. :y
Post by: JamesV6CDX on 11 February 2014, 17:31:57
Arrrrgh I just paid £35 plus the dreaded for a 20l can :(
Post by: ted_one on 11 February 2014, 17:51:15
James your inbox is full ::)
Post by: TheBoy on 11 February 2014, 18:00:06
 :o :o :o
Isn't Dexron III fully synth?
Post by: Shackeng on 11 February 2014, 19:45:26
According to VX, this is the pukka stuff, I asked when I bought it last year. I posted the sheet with the prices on last year, but can't find the post now. The prices are the same as them. :y
Post by: Shackeng on 11 February 2014, 19:47:30
 :o :o :o
Looks like you can have either.
https://www.tradeclub.com/home/news/vauxhall-trade-club-gear-oil
