Omega Help Area => Omega General Help => Topic started by: JamesV6CDX on 13 February 2014, 18:29:43
Since tranny change,
Car now goes forward and doesn't lose drive ;D
The changes are all fine, including 3-4 under light driving, however when giving it large say on overtaking, and then backing off, the final 3-4 change is quite jerky
Solenoid? The 1-2 change is perfect tho, and I think this solenoid is shared?
ATF new, sumps clean, thrust washer intact.
Opinions welcome :y
Are you used to the less refined 3.2's TCM, compared to the superior 3.0l setup?
It's a 3.0 car, all factory original, the box was from a '02 3.2 v6
Does that help? :y
I should add, that 129mph change from redline 3rd to 4th is awful if you lift off and reapply power. As is the 85mph 2nd-3rd, just not quite as pronounced
Does that help? :y
Ah, should be reasonable then. Can still force a (what we call) lag, but not as much as 3.2. If LPG comes in to equation, that makes it worse
Does that help? :y
No LPG on this one, just petrol
I'm thinking solenoid issue
Does that help? :y
I noticed from you wanted post. Not convinced currently, as TCM would flag it
Does that help? :y
I shall double check all codes and data - are you thinking mechanical issue then?
Why does James have so much agro with autos? :-\
Touch wood, but never seen a fault with an auto beyond thumpy changes cured with a fluid change.
Got live data on the box? Thought 3-4 was replaceable. Tbh.
TB, you did 129mph in 3rd :o Where on Earth were you able to achieve this? Autobahn???
Redline 3rd to 4th is a shade under 130mph.
Heyford's runway is a long one :)
Good stuff. I've never heard anyone getting their Omega close to top speed (only because I've never asked).
What did it feel like going that fast in it?
1-2 solenoid also controls 3-4/4-3 shift so given you say the 1-2 change is OK it`s doubtful that the solenoid would be at fault ???
Why does James have so much agro with gearboxes? :-\
Fixed...
Shockingly smooth and quiet....
I took mine to 135 when based in Germany and I can concur. Lovely :y
The XF spent a full 20 minutes at 155 and it was so comfy the missus didn't wake up until we reached our destination and she realised we were 1.5 hours early ::)
Yep, the faster you go, the better they get. :y
I was once the first car onto a freshly reopened motorw- er, private road. Mine sat at 130 just as easily as it does 60mph. Omegas are excellent for driving in a manner likely to cause early arrival.
Now absolutely fine, silky smooth
Wondering if perhaps it was just because it had been sat on the shelf for 3 years
Had a v enthusiastic drive to work, couldn't provoke the issue...
You'll probably find that there's some "learning" around the closed-loop control of the fluid pressure which the ECU modulates to control the "hardness" of the shift, so guessing that took a little while to adapt to the new transmission.
