Omega Help Area => Omega General Help => Topic started by: Ady on 21 February 2014, 20:01:13
I keep hearing a strange electric shorting noise from the passenger seat, glove box area.
Everything seems to be working fine but a bit worried that a noise like that normally means a possible fire risk.
Anybody had this before and maybe know a cure.
Thanks
There are several motors associated with the climate control. Depending on settings, they sometimes function as the ignition is switched on/off :-\
Another possibility could be the heater blower motor... is the scuttle dry around the pollen filter?
One of the passenger door speakers blown?
Under what circumstances does it happen?
Have you tried pulling fuses one by one until it stops? This will help to isolate the possibilities :y
Also what model is your car? The 2.6 is about the only engine fitted across the range ::)
I'd bet on a climate control flap motor.
My first thoughts exactly, but OP hasn't given much to go on :-\
I would also have to be inclined to agree, you can get alot of whiring and buzzing relating to blowers depending on settings.from the dash area ... you could also have a leaf or something rattling around in the vents?? just a thought as these cars are so quiet inside you pick up on every noise going on in there lol
hope you sort it and its nothing major
It's a 2002 CDX taxi al. It has heated seats and mirrors if that helps.
The noise is mostly noticeable when I first turn on the ignition and with out the heating on as it's drowned out by the noise of the blowers so not sure if it still happens with blowers working.
The scuttle was full of water about a month ago resulting in a wet foot well. Tho I've now emptied it and dried the floor, heating works as expected.
Don't think its speakers as I rarely use the radio so normally turned off.
Not tried fuses yet so will have a mess around with them tomorrow.
Concur with other replies. Blend flaps re-synching
That does narrow it down to the heater flaps behaving normally :y
I think it,s fairly normal mate, mine does the same thing when switching ign. off. Had car since last August and no probs. :y
Cool thanks everyone.
I won't worry about it then.
