Omega Help Area => Omega General Help => Topic started by: Bikerdon on 16 March 2014, 14:35:15
Title: Sikaflex.
Post by: Bikerdon on 16 March 2014, 14:35:15
About to go and pick up some sikaflex so I can fit my new lower windscreen seal, was just wondering if its also suitable for use as a seam sealer. Reason for asking is because the bulkhead seams under the scuttle are tatty with the seam sealer on them flaking a bit, so would be as well doing them while I'm at it.
Title: Re: Sikaflex.
Post by: steve6367 on 16 March 2014, 14:48:33
Do you know what you are picking up? Sikaflex is a brand with lots of products...
Post by: Bikerdon on 16 March 2014, 15:06:01
It will either be Sikaflex 265 or Sikaflex EBT.
Post by: 05omegav6 on 16 March 2014, 15:09:04
This stuff...
http://m.screwfix.com/p/sika-sikaflex-ebt-adhesive-black-300ml/79299?filtered=true
Not sure how effective it would be as seam sealer though :-\
Post by: davieboy0312 on 16 March 2014, 15:24:51
as long as you clean and prime it properly it should be fine as a seam sealer
Post by: chrisgixer on 16 March 2014, 18:02:31
Unless the windscreen seal to scuttle is damaged, it doesn't need any adhesive. Just clean it up and re fit with the scuttled removed, which gives you the perfect oppertunity to clean up the scuttle joins and run a bead of any sealant type stuff along to give a water right join. :y
Post by: Darth Loo-knee on 16 March 2014, 20:41:44
Siksflex is magic stuff... sticks shit to a blanket... but there are different tubes for certain jobs.  Used it for years  :y
