Chat Area => General Car Chat => Topic started by: 2woody on 23 March 2014, 20:24:10
the LPG kit that most OOFers have fitted - is this by Stag ?
Indeed it is :y Stag 300+ or variations thereof :y
Yep
Yup, but for V6 you need a decent vap and injectors, as they vary per stag kit. :y
Critical bits are ecu and (some) loom, the rest can be purchased to suit the application/requirements... :y
For example, a kit from a 2.5/6 with a KME silver vaporiser and cheap injectors can be fitted to a working standard and upgraded at a later point as the individual components are all readily available :y
its the software I'm after really - my mate has a Stag kit in his Range Rover and I want to have a poke around
Stag web site has everything you need. Use the polish site though.
Needs a diag cable though...?
You need the right software, which varies with age
Starting point is http://www.ac.com.pl/en/doc/346/instructions-and-manuals
Sycrogas is a software
Aargh! Knew I'd forgotten something :-[
