Omega Help Area => Omega General Help => Topic started by: SMD on 29 March 2014, 15:13:02
I thought removing it would be difficult - it wasnt but clipping it in is proving to be a pain. Its clicked on the tank side (rear) but the front won't click. Its as if being blocked but without the clip the filter goes fully in.
I've tried the clip that came off but still wont go in.
Is the filter the correct way round?
Haven't changed one for ages, what with lpg and all.
Yes. Arrow facing front of car
Done
Put the clip in the pipe first then pushed the filter in
Done
Correct. Sorry, I didn't see this post earlier :-[
No problem. :y maybe the 'how to' should make a note of this point in case someone else gets stuck?
I shall go and look now :y
Which guide, I can only find http://www.omegaowners.com/forum/index.php?topic=90647.0
which has
Fit the new fuel filter clips into the ends of the fuel lines - they should click into place - then fit the new filter into the fuel lines
That's the guide for the thermostat. But you're right, I didn't read it properly, it does state putting the clips in the fuel lines first. :-[ would have saved me an hour
Cock, sorry for duff link, I was cutting and pasting for another thread at same time :-[
