		Omega Help Area => Omega General Help => Topic started by: brian36 on 03 April 2014, 15:25:46
				hi folks just got home and there is a guess water traill to parking space and a foot wide puddle underneath car right in middle at rear of engine any ideas :'(
				If clear water and no taste of coolant then perfectly normal side effect of air con working as it should :y
 If it tastes of coolant then usual suspect is hbv or associated plumbing :y
				to tell you the truth dont know if aircon was on just done school run never paid attention whether it was on or not if i go start now and put aircon on is there away of finding out if culprit?
				Taste the puddle, the cause will be obvious :y
				tastes disgusting take it anti freeze
				any chance any member mechanics around milton keynes? as marks dtm will vouch i aint mechanically minded and he just a bit far away for this
				Sounds like the good old heater bypass valve, just done mine. Cheated and got one of our contractors mechanics to change whilst I went home and put my feet up :y
 I'm probably one of the closest in beaconsfield
				hi thanks for reply just moving to here not sure around area so bear with me will have to google maps, i take it i may need a hbv for my f/l 2.6 mv6 anyone know where please
				Interested to know what the results of this diagnosis is as i have an identical issue.
				Brian
 I assume this has just started happening in the last few days?
 Does the leak vary dependent on climate setting?
				As Marks DTM suggests, if its leaking when climate set to HI (for eg), try it with climate set to LO, or vice versa.  This usually points to HBV, about £30+VAT from dealer, trade, although avoid the scumbags at Crownhill (V4, between H5 and H4).  I'm told a new dealer has recently opened at Kingston, near the BP, on the way to the M1 Jnc 13. No idea if its Crownhill moving, or a separate dealership.
 I'm in Brackley, on the Bucks/Northants/Oxon border if you need a 2nd opinion, or help.
				New dealer info
 http://www.thurlownunn.co.uk/locations/milton-keynes/
				hi mark etc so today filled up reservoir it was about 2 inches from max so filled up to just below line drove to work  with aircon on and set at 19 i tried heat on and then on low temp went up a bit when heat on to around 90 then back down to 85 when i got to work it has lost about a inch in reservoir.
 drove home tonight and still sitting roughly same and no puddle or trail when reversing into space also checked foot well that dry. think i need someone to have a look so if you theboy are free over weekend can you have a wee look? would help me out need car for my new job just started thanks :)
				Brian
 yes just yesterday
				New dealer info
 thanks yip even know where it is pass it daily to and from work will get car looked at and get one asap if this the case thanks
 will try in morning hard day need to sit down thanks :y
				so the update, after initial leak which lost me about 2 inches in expansion tank i filled up and since then nothing. have had aircon on at hi and ran for about 15 mins then put on low for same i then drove back and forward work 2 days still ok weird or what?
 will keep a eye on it but thanks to all :y
				You'll most likely find it all escapes at one temperature setting. Try a different temp each day until it leaks...
 The only consistency with HBV failure is that the temp is always different ::)
				Symptoms are typical of HBV.
 I would buy a new HBV anyway so that it is in the car ready to fit when the old one fails completely.
				ok i reckon will buy one just in case and thanks again :y
 theboy
 hi would you be able to have a look if can get over to you this weekend if you are free? would appreciate it thanks
				Had a gander at this today, although buggered if I could get it to leak, using the modified cap and pressurising to about 10psi method  :-\
 Valley is bone dry, no hint of leak from stat, cooler plate, bridge, HG (to outside of block). Good job there, Mr DTM :y
 Bits of radiator that are visible all looked good, as did rad hoses. Curly hose from bridge to HBV looks good.
 Tell tale signs ("rusty" look) of a leak around HBV, which would fit in with brian36's diagnosis of where he's seem coolant under car, and with his observations with the climate settings within the car.
 Disappointing I couldn't 100% prove the leak, but given what I've seen, the HBV is what I would do :)
