Omega Help Area => Omega General Help => Topic started by: badmuver on 06 April 2014, 14:12:30
Title: obd 2 scanner
Post by: badmuver on 06 April 2014, 14:12:30
Hi all, i'm looking at getting a scanner for my car, I've found this one i was just wondering if it is and good.
<Link removed by Admin>
cheers   :)
Title: Re: obd 2 scanner
Post by: zirk on 06 April 2014, 14:17:57
cheers   :)
Says this ? - XP SYSTEM ONLY
Post by: badmuver on 06 April 2014, 14:19:35
yep i've got a old netbook on xp  :)
Post by: RobG on 06 April 2014, 14:28:44
Chinese shite. Click on "contact details" bottom left of page and you`ll see this
黎杰仪
白云区时代玫瑰园三期H2栋403房
510440 广州市, 广东省
中國
Post by: plym ian on 06 April 2014, 14:53:42
I brought a maxiscan 309 for about £13 quid off eBay. Works rather well tbh
Post by: Entwood on 06 April 2014, 15:13:26
That is NOT a "Tech2" .. it is an ELM327 .. and a clone one as well .. touch not with a bargepole IMHO..
A proper "Tech2" will set you back a lot more than that ...
http://www.diagtool-uk.co.uk/GM_TECH_2_VETRONIX_DIAGNOSTIC_TOOL_INC_32MB_VAUXHALL_CARD/p2499210_11579572.aspx
Post by: badmuver on 06 April 2014, 15:17:35
Cheers RobG for pointing that out.  ;D
plym ian,  maxiscan 309 what dose this one cover.
Post by: Entwood on 06 April 2014, 15:23:32
Read about the Maxscans here ... all made by Autel .. again .. avoid ebay as most of those are illegal copies that generally don't work..
http://www.auteltech.com/
I have the GS500 (no longer made) that is an early Autel maxscan .. excellent bit of kit, but only does engine and a little bit of transmission
Post by: badmuver on 06 April 2014, 15:23:57
cheers lucky i didn't get one.  :)
Post by: badmuver on 06 April 2014, 15:34:51
So would the maxiscan 309 cover the light that comes up with the car and the spanner in the middle, as it bugs me when i am driving and it comes on.  :(
Post by: plym ian on 06 April 2014, 15:51:55
All codes cause by eml on. Not sure about spanner light :(
Even told me had misfire on pot 4 as well :y
Post by: TheBoy on 06 April 2014, 16:10:23
Links removed as looks suspiciously like an illegal copy of a commercial product.
Post by: badmuver on 06 April 2014, 17:49:36
cheers everyone  :y
Post by: Webby the Bear on 06 April 2014, 17:59:06
Good luck getting an Autel to read Omega codes. Will read live data though.
That's not to say the Autel isn't a good scan tool. It's read and erased codes from every car I've used it on except the Omega. Handy for me as I work on lots of cars but as said don't expect it to read Omega codes.
Wonder why it won't?  :-\
Post by: Entwood on 06 April 2014, 18:53:17
Autel GS500 reads codes, erases codes, reads live data on mine, and every other FL omega I've tried with ease .. although it doesn't work on PFL, and has limited success on MFL .. its all to do with the OBDII standard .. if the car is not OBDII then the maxscan can't read it .. :)
Post by: TheBoy on 06 April 2014, 19:02:13
Remember the facelift 2.0, 2.5 and 3.0l are still not EOBD/OBDII compliant
Post by: Entwood on 06 April 2014, 19:04:40
Perhaps I should have said "every other DBW omega I've tried with ease"  then ..  :)
Post by: badmuver on 06 April 2014, 19:24:31
 :y :y :y :y :y :y
Post by: TheBoy on 06 April 2014, 21:19:00
Still not technically correct, as it won't do the DBW 2.5TD U25DT or X25DT engines either.
The EOBD Omegas are 2.2 (petrol and diesel), 2.6 and 3.2 :)
Post by: Grrrrrr on 07 April 2014, 23:07:50
I got a little blue one that bluetooths to my phone and I run it with Torque. Works very well. £15 from a well known online book store. Small enough that I can run the car with it in and the fuse-panel shut.
Post by: Entwood on 07 April 2014, 23:15:12
yup they work well .. just DON'T forget to take it out once you've finished .... the test socket is always live, and it will flatten the battery in about 5 days ....  (or so I'm lead to believe ...  ::) ::) )
