Omega Help Area => Omega Electrical and Audio Help => Topic started by: Toledodude1973 on 06 April 2014, 21:50:02
Title: light units
Post by: Toledodude1973 on 06 April 2014, 21:50:02
Ebay are selling new xenon hid light units (89.99)each :o They come without ballast, can this be just changed over from my originals on my elite?. I'm cleaning my lenses first , this is just in case it doesn't go well, thanks for help
Title: Re: light units
Post by: RobG on 06 April 2014, 21:56:36
Yep.
Link for the bay ???
Post by: Toledodude1973 on 08 April 2014, 19:48:56
thanks for reply Rob,sorry dont know how to do links but item number on ebay is 360507140840, i have a 2.6 2002 elite so will this unit fit with my original ballast      cheers
Post by: Andy B on 08 April 2014, 19:52:42
360507140840 (http://www.ebay.co.uk/itm/360507140840?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_sacat%3D0%26_from%3DR40%26_nkw%3D360507140840%26_rdc%3D1)  :y
Post by: Toledodude1973 on 08 April 2014, 20:02:47
Thats the ones, suitable for my car?
Post by: Andy B on 08 April 2014, 20:08:30
According to the advert they are  :y
Post by: Toledodude1973 on 08 April 2014, 22:42:44
thanks Andy
Post by: powerslinky on 09 April 2014, 07:55:27
if you are looking for a pair . . . From that item no.    looks like there is only one available  Paul  :-\
Post by: Toledodude1973 on 10 April 2014, 19:22:57
They did have the other side listed on its own Al , hoping to clean them up but not a lot of time at the moment Mother is poorly  :(
I really fancy a nice shiney set ,i know they're expensive but you only live once ;)
Post by: powerslinky on 10 April 2014, 20:09:29
Me too Paul  . .  . but a pair of them come to half of what I paid for this MV6 :o :o     ;D ;D ;D
Looks like 1200/200 grit & then plenty of elbow power with G3  for mine .
Little bruv does have a decent polisher though ;) ;) ;)  I'll have a lend of that  ::) ::)
Post by: Toledodude1973 on 10 April 2014, 20:31:09
Yes mate i'm with you big polish first :y
Post by: dbug on 10 April 2014, 21:05:25
I've done them successfully before Al on all the Omegas we've had - wouldn't go as coarse as 200 grit - used 1000/1200 on mine, then G3, followed by TCut then waxed.  Keep them well wet when using the wet and dry :y
Post by: Toledodude1973 on 10 April 2014, 22:27:47
Thanks Dbug, will follow your lead :)
Post by: dbug on 10 April 2014, 22:44:22
You're welcome :y
Post by: powerslinky on 11 April 2014, 07:20:54
O0ps ! typo  . . . meant 1200 first then 2000
Post by: powerslinky on 11 April 2014, 07:22:45
+1  :y
I am presuming that this can be done with lights in situ & no need to remove from car ? :-\
Edit:  Best I check out the maintenance guide ::) ::) if nothing there , I'm sure there is a demo video or 2 on You tube  ;)
Post by: plym ian on 11 April 2014, 08:08:26
+1  :y
Seen a few on there. One guy seamed to get good results from an advacardo  :o
He even tried urine if I recall :o :o
Post by: dbug on 11 April 2014, 21:27:58
+1  :y
You presume correctly Al  :y - may be worth masking surrounding paintwork - depends how steady your hands are  ;)
Post by: powerslinky on 11 April 2014, 21:56:38
+1  :y
Shakey nowadays Colin  ;D ;D  BTW  tried a small area with just G7 compound by hand polishing  . . .  has worked wonders & come up really good . So will go that route first before I use any wet & dry  :y
Post by: dbug on 11 April 2014, 22:35:45
+1  :y
If it works for you Al, go for it - wet 'n dry needed for bad cases :y  The shakes - age or booze ?  ;D ;D ;D ;D ;D :)
Post by: powerslinky on 13 April 2014, 20:04:45
Polished  mine up today . .  G7 first . . .then T cut  with polisher/buffer & sponge pad  & finished off with a hand polish with Mer
Come up very well , almost look new  :) :) :)
Mine were quite well pitted & off colour but still did not use any wet & dry . Each lamp took about 10 mins  ;)
Post by: the alarming man on 13 April 2014, 20:16:47
+1  :y
Combination of both eh Al?????
Post by: Toledodude1973 on 13 April 2014, 20:51:49
Used Plastex cleaner , with pad on drill, lights have come up pretty well ,won't need to go down replacement route just yet Al ,thanks all for advice :y
Post by: GastronomicKleptomaniac on 13 April 2014, 21:23:39
I got the headlight restoration kit by Meguiars, brought mine up a treat. £15 for the kit includes sanding pads, wool drill attachment, and a bottle of PlastX :y
Post by: Toledodude1973 on 17 April 2014, 22:41:04
Yep definitely works, just takes a bit of perseverance ;)
Post by: Magwheels on 17 April 2014, 23:44:24
I rubbed down my headlights with 1200 wet n dry (wet) then gave them a coat of "2k" lacquer (that was not 2 pack) and they looked like new and have remained that way for about 3 or 4 years now. Total cost nothing as I had the stuff sitting in the garage after painting my bikes.
It feels like a job well done after getting some sparkle back in the old girls front end and is one of the easiest jobs I have done on the car to be honest and you get to actually see the result of the work put into it unlike fixing the mechanical stuff!!
Post by: Toledodude1973 on 18 April 2014, 20:30:36
Was the 2k lacquer just out of an aerosol can? Is that different from normal lacquer?
