Chat Area => General Discussion Area => Topic started by: omegaman2 on 13 June 2008, 12:40:49
Title: pit needed
Post by: omegaman2 on 13 June 2008, 12:40:49
oil change now due
have the filter and the oil but no where to do it as the garage and pit haave been pulled down / filled in
Title: Re: pit needed
Post by: Richie London on 13 June 2008, 12:52:20
i did mine on 1 axle stand, no problem. tell a lie i dropped the plug in the oil  ;D ;D ;D
Post by: Jimbob on 13 June 2008, 12:54:39
Thats one of those things that tends to happen once, you keep a suprisingly strong grip on it the next time  ;D
Jack & Axle Stand is all I use
Post by: Elite Pete on 13 June 2008, 15:26:44
Im doing an oil change at the moment on axle stands, just waiting for the oil to drain.
Post by: omegaman2 on 13 June 2008, 15:29:43
but does your oil catcher not get stuck in the plastic under pan when you lower the car to get it level :question
Post by: Elite Pete on 13 June 2008, 15:33:12
Im lucky as my drive has a slight slope so I put the rear of the car at the top and then jack the front until its level, jobs a goodun :)
Post by: Jimbob on 13 June 2008, 16:19:43
Kinda just clears it, you could always get a shallower catcher
Post by: Richie London on 13 June 2008, 16:22:33
i put my oil catcher in a large baking tray, not a drop on the drive  :y :y
Post by: Jimbob on 13 June 2008, 16:26:14
I use on of these after seeing Mark use one
http://www.machinemart.co.uk/shop/product/details/14-litre-oil-drain-pan
Dont spill a drop, big enough and strong enough for all drainage jobs
Coolant / Oil / ATF
and a nice spout to drain from afterwards, cos when I used to use an old washing up bowl, took me longer clearing up spilled oil than the change did
Post by: Tony H on 13 June 2008, 16:28:05
Take the oil catcher from under the car before you take it off the axel stand :y
