Omega Help Area => Omega General Help => Topic started by: RolandL on 28 April 2014, 19:18:20
Hello, does anyone know the best way to refit the windscreen surround trim (single one piece) Mine had to come out recently, and I am struggling to get it back in its channel.
Thanks
hi. try soaking the rubber in cooking oil over nite then put sum in the channell. shld slide into place easy. ;D
what I do when fitting a new screen to an omega is spray with watered down washing-up liquid and press back into plastic back trim with your thumbs only! don't use a rubber hammer to "tap it in" push til it clicks in, sorted :y
They don't like being refitted more than once :-\
When I had mine refitted after screen Change it never clipped back in properly at all. Probable needs new one :)
I have changed these screens many times and never used a trim set on them yet the outer trim is reuse able just got to take refitting
Pattern ones can be crap...
It wasn't a pattern one :(
If you lube it up properly and push til it clicks it will sit properly. Just push at trim not on glass or you will split screen
phew ;D
Thanks guys, will give your suggestions a try :y
