Omega Help Area => Omega General Help => Topic started by: blackviper90210 on 05 May 2014, 13:12:58
Hi all,
After having made a first attempt at changing an oil cooler yesterday, I refilled the cooling system with water and cleaner and refilled the oil.
Car started after a few attempts and ticks over fine.
Unfortunately I now have a spanner light lit up??
Using my Sealey code reader, it's says there are no codes, but if I select clear codes, the light goes out, but then a few seconds later, comes back on ???
Any suggestions as to what maybe causing this please?
TIA :y
Double check all electrical connections,dual ram at rear of plenum can be easily missed :y
Is that the large plug right at the back? If so, I did connect it, but I'll go and check it's still is :y
And maf connection ..
Thanks for the replies. As soon as SWMBO returns and takes the kids off me! I'll go and have a look :y
Does the code come up with a peddle trick?
Really need the code mate via pedal/paperclip test but I wouldn't be too concerned.... the code will more than likely relate to something you forgot to re-connect bearing in mind you just did quite a big job with it.
TPS is the one I always forget to reconnect ::) ;D
Never thought to do a paper clip test :-[
I'll do that at work tomorrow. Ref TPS, what is that?
cheers,
Dave
throttle position sensor
Pedal trick not paper clip test :y
