Omega Help Area => Omega General Help => Topic started by: DrAndyB on 06 May 2014, 16:50:07
Title: Full Geometry setup done - Nigel Langs Bolton - WOW WHAT A DIFFERENCE
Post by: DrAndyB on 06 May 2014, 16:50:07
Hi,
I said I would report back after full Geo setup and thought I would post the before and after  :D
Well, after 2 new wishbones (fitted by Daz - Cheers  :y) I went to Nigel Langs today for 4 new tyres (Uniroyal Rainsport 3's), Geometry setup and A/C vac and refill/re-gas (A/C had 50gms refrigerant left from the 950 when car new !!! No leaks  :y so filled back up again and froze to death on way home  :y :y).
I would HIGHLY recommend the place.  Professional, Pete CERTAINLY knows his stuff and car totally transformed - like NEW again  :y :y :y  Would trust them with any car of mine and my steering wheel is now FINALLY STRAIGHT  8)
Car was way out, and crabbing a little.
The two new front Trackrods I bought were not needed, so I have a pair going to highest bidder  ;) Bought from http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=371053376220 (http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=371053376220)
Car handles great now, no wheel shake, no feeling like would catapult me off road  ??? and straight as die - I even ventured above 69mph (a tad  :D) and all felt solid and safe again  :y
Well chuffed.
(http://i1189.photobucket.com/albums/z436/andybeddoes/Image0001.jpg)
Title: Re: Full Geometry setup done - Nigel Langs Bolton - WOW WHAT A DIFFERENCE
Post by: Darth Loo-knee on 06 May 2014, 18:58:48
Nigel Langs is by far better than WIM. They give far better service I found personally.
Glad your car is sorted and driving how it is supposed to x
Post by: DrAndyB on 06 May 2014, 19:21:08
Even out dragged a BMW 320D from lights to his surprise with my 4 new boots  ;D and still averaged 36mpg on way back from Bolton.  Must be the engine timing and cam belt   ;)
May need rear brake flexies doing later in year.  Not sure when brake fluid changed.  Will pm you later in year if your interested  :y
Ttfn.
Post by: Toledodude1973 on 06 May 2014, 20:23:27
You sound like your enjoying the car again :y ;D
Post by: chrisgixer on 06 May 2014, 20:37:58
Very precise figures :y
Post by: mickyboy123 on 06 May 2014, 21:02:46
hi drandyb, have you got post code for the place, may get mine done, it feels way to unsstable and light it doesnt pull but it feels to light if you get me
Post by: RobG on 06 May 2014, 21:04:52
BL3 6AS
Post by: CaptainZok on 06 May 2014, 21:09:19
http://www.nigellangsgarage.co.uk/
Post by: mickyboy123 on 06 May 2014, 21:12:07
thank you, :y
Post by: Bigron on 06 May 2014, 21:17:37
Are ALL the best places up north? That's nearly 250 miles from me!
Ron.
Post by: Entwood on 06 May 2014, 21:47:53
Ron.
WIM, Chesham, will be a tad closer to you .. :)
Post by: DrAndyB on 06 May 2014, 22:06:11
Looks like others have sorted you with details for Nigel Langs  :y I would highly recommend the place.  Car is a joy and fun to drive now  ;)
Post by: Keith ABS on 07 May 2014, 07:49:26
  Bigron, give Europit a look at Heybridge, Maldon. I have had mine done there and also the ABS chairman has to. We used to go to supertyres but after a management change, they were a waste of space. Supertyres used to get a lot of the ABS Lotus Carltons to do, but not anymore
Keith B
Post by: mickyboy123 on 07 May 2014, 08:06:59
i was doing some research and nigel langs is a 524 mile round trip for me, its a shame as he is highly recommended, i found a place local to me that does it in brighton, will post read out when its done. be intresting to see how it compares. wish me luck. :y
Post by: wheels-inmotion on 07 May 2014, 09:29:07
Lang's are very good, nice to see they use the revised geometric positions i wrote for the Omega and gave them. Pete is top of his game in regard to customer care and never to ashamed to call me if he has a problem outside of the box.
Post by: mickyboy123 on 07 May 2014, 09:57:06
just a quick question , how much does it normaly cost for a full geometry setup ?.just want to be sure im not being ripped off.  :y
Post by: Bigron on 07 May 2014, 16:15:32
Thanks Keith.
Europit have a place in Hatfield Peverel, just down the road from me - are they the same firm? They seem to be a small, low-rent outfit, doing part worn tyres and with a shabby-looking yard, not inspiring confidence in their ability to perform posh adjustments!
I've done 130k miles in my Omega and may be on the original wishbones (My contribution to the total is 50k miles) - due for replacement?
Ron.
Post by: DrAndyB on 07 May 2014, 19:00:10
I paid £75 and well worth it.  Also had 4 new tyres and A/C done at same time  :y
Post by: brian36 on 07 May 2014, 19:18:49
can i ask ? on page one there is diagram of geometry set up for up to 99 models does anyone have for f/l models or figures should be? many thanks :)
Post by: chrisgixer on 07 May 2014, 19:28:39
Same.
Post by: chrisgixer on 07 May 2014, 19:32:33
Depends. Wim and its franchises charge around £100, but the head office in Chesham offer a discount to oof which brings it down to circa £70.
Micheldever charge £20 per adjustment. Nothing to measure.
Ring whoever is nearest and get a quote...?
Post by: brian36 on 07 May 2014, 19:37:17
Same.
thanks for that :y
Post by: YZ250 on 07 May 2014, 22:00:14
I mentioned OOF when I phoned to make the appointment and again when I got to Chesham but I still got charged full whack.  :-\ :-\
Perhaps I'm not forceful enough.  :-\
Post by: mickyboy123 on 08 May 2014, 19:26:03
hi, just an update, should have had my print outs for you to look at today, but can you belive this ,they did there before test, rear was all within the manufatures limits front was out, they just started to adjust front and one of there camaras decided to stop working, so job not finished have to wait for them to get new camera,  :'(a
Post by: Mr Gav on 08 May 2014, 20:22:26
I had mine done at Nigel Langs and I was impressed too, as Arnie said....I`ll be back  ;D
Post by: mickyboy123 on 08 May 2014, 20:24:14
just wish i lived nearer  >:(
Post by: steve6367 on 08 May 2014, 20:24:40
Anyone used these guys?
http://www.christchurchtyre.co.uk/wheel-alignment.html
Trying to find someone local.
Post by: omega squared on 08 May 2014, 20:51:04
For anyone in West London there is a very good place near Heathrow with the Hunter set up (never used them for an Omega but they did a good job on my Mitsi Evo 9Gt).
Post by: omega squared on 08 May 2014, 20:57:53
here is a link to Feltham Tyres, just near Heathrow T123/ Bath Road
http://www.felthamtyre.co.uk/alignment.html
