		Omega Help Area => Omega General Help => Topic started by: speed_demond on 18 May 2014, 12:41:53
				99 omega losing power on pull off and through 2nd and 3rd,,feels like when your traction control kicks in but its not that,no lights coming on dash,regards
				Do a paperclip test for codes. Also check plugs for oil or water  :y
				thanks for your response ,,but what is a paper clip test ???
				Read maintance guides all in there,and i can supply you a paper clip for £30 recorded delivery  ;D
 http://www.omegaowners.com/forum/index.php?topic=90581.0
 Hi  ;)
 Did you find out what the problem was because I'm experiencing the same thing too. I'm gonna change the plugs in a couple of days and see if that works. I don't have any engine lights showing and I've had the same problem with another motor in the past and I changed the plugs and leads and solved it.
 Cheers
 Anthony
 Hi  ;)
 Cheers
 Anthony
 no not yet going to do the same as you change the ht leads and plugs(nightmare) see how we go then Anthony,,,
				Hi again..99 omega losing power on pull off and through 2nd and 3rd,,feels like when your traction control kicks in but its not that,no lights coming on dash,regards
 Hi  ;)
 Cheers
 Anthony
 Im doing the plug change on Saturday and I'm gonna give it my best shot following this guide:
 http://www.omegaowners.com/forum/index.php?topic=90536.0
 I'll see if that solves it.
 Cheers
 Anthony
 Hi  ;)
 Cheers
 Anthony
 Cheers
 Anthony
 ok good luck,,let me know how it goes Anthony
