Omega Help Area => Omega General Help => Topic started by: brian36 on 05 June 2014, 17:54:22
Title: wishbone nuts/bolts
Post by: brian36 on 05 June 2014, 17:54:22
hi all, got let down by vx milton keynes,ordered new bolts for wishbones getting fitted saturday,now they say could be a few days as on back order. anyone close by that have a spare set new ones?
oops think in wrong place,admin can you help sorry!
Title: Re: wishbone nuts/bolts
Post by: biggriffin on 05 June 2014, 18:20:25
Take the old ones to any fastner supplier think they are m14 cant remember the length. Or go to VX and ask them for the size, will cost,pennies :)
Post by: YZ250 on 05 June 2014, 18:27:09
Are the old ones unusable for now then?  :-\
Post by: Marks DTM Calib on 05 June 2014, 18:34:30
No, you can reuse the old ones, no problem at all. There not tightened to the point of yield
Post by: chrisgixer on 05 June 2014, 18:36:19
Never replaced a wishbone bolt, it's unnecessary. Yes I know vx say to replace them.
If you use the search facility you'll find all the old posts.
Do replace the pinch bolts on the hub though, if they come with wishbones like lemforders do.
Post by: YZ250 on 05 June 2014, 18:47:46
Neither have I. They're quite chunky and don't appear to suffer any ill effects from being under the car.  :y
Post by: brian36 on 05 June 2014, 19:13:01
thanks for all, will find out i guess on saturday,but hopefully all ok, have wishbones ready to go in with their new poly bushes. :y
Post by: chrisgixer on 05 June 2014, 19:17:29
I'm sure your aware but, makes sure they tighten the front bolts wheels loaded/suspension at the usual ride height
Post by: martin42 on 05 June 2014, 19:44:30
 ::) they will be  :D
Post by: chrisgixer on 05 June 2014, 19:46:41
::) they will be  :D
Heat they want new bolts to swing on. Interesting. :)
Post by: Entwood on 05 June 2014, 19:59:36
I have a spare one you are welcome to ....  all you have to do is fish it out of the subframe/chassis rail hole ...... :(
 :D :D
Post by: chrisgixer on 05 June 2014, 20:03:48
::) they will be  :D
Yet....
