Chat Area => General Discussion Area => Topic started by: Andy B on 06 June 2014, 11:33:56
Title: wiring help
Post by: Andy B on 06 June 2014, 11:33:56
I recently bought a cigarette plug for my travel fridge  http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=151234620911 Just opened it up to wire it, expecting to find screw terminals to fit the wires .... but no such luck.
Am I soldering my fridge wires to where the resistor & diode are already soldered so the diode & resistor are across the feed to the fridge?  :-\
(http://i84.photobucket.com/albums/k17/Tiff4327/20140606_112320_zps8d5ea3ef.jpg) (http://s84.photobucket.com/user/Tiff4327/media/20140606_112320_zps8d5ea3ef.jpg.html)
Title: Re: wiring help
Post by: Kevin Wood on 06 June 2014, 11:38:48
Yep. :y
I assume you've got the pin from the end? ;)
Post by: zirk on 06 June 2014, 11:43:14
First thing is if its not fused, chuck it in the Bin, but I assume the fuse goes in th the center part and is not shown in the picture.
So, +12V (Pos) gets soldered to the centre pin, left of the LED and Ov (Neg) gets soldered to the Upper outer pin left of the resistor,
The Resistor (current limiter for the Diode) and Diode just indicate that the plug is live when pluged and will not have amy effect with the 12V feed to the Fidge.
Chris. :y
Post by: zirk on 06 June 2014, 11:52:35
Just to add, I would expect some sort of clamp at the end, to stop stress on the wires / plug, should it get pulled out by the feeder wire, some cheap ones just tie a knot  in the wires before the rubber grommet, but you would need to sort something there, if no restrainer fitted.
Post by: Andy B on 06 June 2014, 12:32:39
Thanks to you both ......
Yes, there's a fuse that lives in the middle bit and the +ve bit that's sprung against the fuse is screwed into the thread showing.
Ta  :y  :y
Post by: Andy B on 06 June 2014, 12:42:04
This is it in all its glory. No clamp for the cable, I'll see if I can get a small cable tie in there.  :y
(http://i84.photobucket.com/albums/k17/Tiff4327/20140606_123704_zps9640078a.jpg) (http://s84.photobucket.com/user/Tiff4327/media/20140606_123704_zps9640078a.jpg.html)
Post by: Andy B on 25 July 2014, 22:10:59
Has anyone a suggestion for a decent 12 volt cigar plug, suitable for a 6 amp camping fridge - this was supposed to be rated at 10A ...... the one above had melted itself by the time we'd got to France ..... no idea at what point. I didn't see the point in accepting another from the supplier. And I emailed Tristar - the fridge maker - and they were as much help as a chocolate fire guard  ???
This post proved useful as I think he wanted to question how I'd wired it up, but I just pasted him the link  ;D ;D
Post by: Bigron on 25 July 2014, 22:58:37
Will this help you, Andy?
www.roadking.co.uk/plugs-and-connectors/2-in-1-pro-car-16-amp-cigarette-hella-plug.html
Better quality than Poundland ones!
Ron.
Post by: Vamps on 26 July 2014, 00:20:13
Ron.
 :y ::) ::) ::)
Post by: Andy B on 26 July 2014, 06:36:28
Ta. Worth a try  :y
Ron.
Post by: zirk on 26 July 2014, 12:12:14
THey do get hot, surprised the one you had melted though, Ive used that type before, always found them to be good, a nice tight fit into the socket, maybe its a crap chinese copy, lake of cable clamp was probably a clue  :-\.
Does it need to be wired to a ciggy plug?, Ive used UPS's and stuff in the back of the Estate and have Hard Wired them in via an Anderson Connector and fuse a lot neater job and higher current rated  :y
(http://www.12voltplanet.co.uk/user/products/Andrerson_SB50_120A_double_pole_power_connector_grey_16mm2_cable_1[2].jpg)
Post by: Andy B on 26 July 2014, 13:02:20
It wasn't a moulten blob ...... but it'd had meld inside enough that it put up a fight when I opened it.
As long as it's powered up I suppose it could be connected with anything ........ that looks like a mini version of a fork truck battery connctor. I might look into that because there is a good 12 volt connection in the boot for the rear SAM  :y  :y
Post by: CaptainZok on 26 July 2014, 13:10:16
Have a poke through the RS catalogue in the sparkys shack at work Andy, bound to be some connectors that fit the bill.
Post by: Andy B on 26 July 2014, 13:11:47
You must be joking ....... the best I'd find at work is a roll of insulation tape for use after I'd twisted the wires together  ::)  ;D  ;D
Post by: CaptainZok on 26 July 2014, 13:17:30
Sorry mate I was forgetting, electricity is still regarded as a form of witchcraft in parts of Pieland.
Post by: Andy B on 26 July 2014, 13:27:22
They had problems the other week trying to keep the HV stuff in the cables ........ though the fire was very quickly contained!  ??? ??? ???
Post by: 05omegav6 on 26 July 2014, 13:36:44
Along with inside toilets and running water ::)
Post by: Andy B on 26 July 2014, 13:38:26
Steady .......  ::)
I didn't have a inside toilet till I was 8   ;)
Post by: CaptainZok on 26 July 2014, 13:48:23
God only knows how the mining industry survived as long as it did round there.
