Chat Area => General Discussion Area => Topic started by: pauls on 10 June 2014, 21:17:21
Can you check if cancer has spread to your lymph nodes by using blood tests or a mri scan
Or do you have to have surgery. I know its a bit of a big question but i want some indepenant answer.
Can you please answer if you know, not what google says. I have read all of that.
ps. If admin thinks this is not the sort of subject that should be aired then please delete.
thanks Paul
You need biopsy to assess.
had a few just lately, :)
be a Dr along shortly.. ;D
I doubt there is anyone here who knows Paul.
Although Guffer might, thinking about it.
Try a ring back with your gp as well. :)
I think they can get an indication from an MRI or PET scan, but I think the only sure way is by surgical removal and analysis. :-\
Note though that I'm not a Dr............... Unlike many! ::)
for exact results biopsy. not googled
mri with contrast highlights the areas, a biopsy is a definitely way.
what i said, i don't need google..got the t-shirt. 2 kidney and 2 lymph nodes. :y
No. A PET CT may give you a very good idea, but the gold standard test is a biopsy, either surgical or guided by a CT scan.
