Omega Help Area => Omega General Help => Topic started by: Andy663 on 18 July 2014, 19:28:56
Hi, I'm needing two return springs for my rear brakes. The rear hub gets warm when driving due to one of the levers pressing against it, if the lever is manually pushed back and I don't use my handbrake will it be okay to drive until I can get the springs fitted?
thanks
Are you sure it's not a stiff handbrake cable?
I bought these for mine from flea bay...item number....131241957185...£8.02 including postage :y
Thanks, I got a set from my local stealer, £6.50.
I have never known them get weak. The right hand pull off spring is easy to remove, the left hand is difficult and I usually end up cutting it. Do others find this?
I found the new one on nearside toughest get on , old ones ... one corroded in half and one missing . New ones all greased up :y
