Omega Help Area => Omega General Help => Topic started by: engineerkeith on 26 July 2014, 13:30:24
Title: Drivers door locked, remote system working, all other doors open normally.
Post by: engineerkeith on 26 July 2014, 13:30:24
Cannot open the door and cannot remove the trim to check for broken linkage.  Any ideas where a hole can be drilled through the trim to the lock where with suitable "tools" the door can be unlocked.
I am prepared to ruin the trim if need be.  I am sure this problem has occurred before to other owners.
Title: Re: Drivers door locked, remote system working, all other doors open normally.
Post by: 05omegav6 on 26 July 2014, 13:32:52
Drop the window, then pull the button up with molegrips or similar, then open the door :y
Replace or repair the drivers door central locking motor as per the guide :y
Post by: chrisgixer on 26 July 2014, 13:42:14
Have you tried the key in the lock? You do need to force it over to 90degrees, and button may not pop up, but the door should open.
Post by: engineerkeith on 26 July 2014, 14:10:47
Thank you for the advice.  The central locking is all working OK but it appears that a link has come adrift as the inner and outer handles seem OK.  Something has disconnected from the lock assembly.
Post by: RobG on 26 July 2014, 14:12:59
Reply #2
