Omega Help Area => Omega General Help => Topic started by: skyblue on 29 July 2014, 19:00:32
Evening all, Just been looking at Steve's parts website.Can anybody tell me what the following part is for and where it is located,
The full description is Auto RPM gearbox output sensor. Part No 96014422.
(https://dl.dropboxusercontent.com/u/70807181/sensor-96014422-velocidade-cmbio-automatico-omega-30-93794-13910-MLB147188160_9049-O.jpg)
that's it, any clues to where it is and what it does ????
Transmission > Speedometer feed :-\ :-\
Autobox determines input speed via the engine RPM, output speed is determined via aforementioned sensor. If box is in incorrect gear dependent on these values the box ecu will raise a code
is that it rob :-\
(https://dl.dropboxusercontent.com/u/70807181/speedo.jpg)
So if the sensor was knackered the car would pull away as if it had a 10 ton weight on the back of it ??? ( Sorry if this is like pulling teeth for ya , but I just wanna be sure I am getting the right part to sort my auto problem)
Have you got any codes :y
The only code I know of was 0704. I think that is what it was before it was cleared by my local mot centre. But He thought It was connected to the auto selector switch problem I have and still need to sort :-[
I recently had a problem with the 'selector switch' - only 3 gears, lumpy gearchanges, poor getaway. No switch available in UK. Got one from the US for £38. Any help?
I'm sure this would be very helpful to myself and others on here who are also having this problem with there autobox. Could you please put up a link or PM me the details of this company. Ta very much :y
Always seem to be available in the secondhand market here ???
Bit of confusion here :-\ :-\
(https://dl.dropboxusercontent.com/u/70807181/selector2.JPG)
