Omega Help Area => Omega General Help => Topic started by: Tony H on 22 August 2014, 18:02:18
Title: Steering parts
Post by: Tony H on 22 August 2014, 18:02:18
Evenin' all, I've just been searching the net for a steering idler arm. Came across a company called Algermanparts and they had two arms listed one made by Febi Bilstein at a cost of £22.54 and another made by Lemforder at a price of £42.52 quite a price difference  any opinions as to which one to go for my local factors want £84.00 for one   :o and I don't even know what make it is.
TIA
Tony
Title: Re: Steering parts
Post by: X30XE on 22 August 2014, 19:31:23
Not long fitted a cheap one to mine (think it might be the FB one you're referring to). Not as stiff as I would have expected (ooh err mrs) or hoped  :-\
But then GM price is a blatant proverbial take and it's a stupid design in terms of the forces acting on the bush, so can't win really.  :(
Post by: ted_one on 22 August 2014, 19:35:03
Got Febi idlers on two of mine and have one to go on too car three....not had any problems so far :-\
Post by: Nick W on 22 August 2014, 19:55:25
Omegas have a number of suspect design ideas, but the idler isn't one of them. BMWs have the same sort of thing. In fact, it's hard to think of any other way of doing it.
Post by: X30XE on 22 August 2014, 20:21:52
I disagree, anything that has that much leverage on a rubber bush is doomed to fail.  :P
Wheel hits bump - track rod is compressed - idler arm deflects upwards - wheel changes direction - steering input required to avoid hedge.
Prevailing methodology on OOF for obtaining reasonable handling/tyre wear on a ten + year old omega : replace everything and send to wheels in motion.  ::)  :)
Post by: Nick W on 22 August 2014, 20:42:12
There isn't a rubber bush in the steering idler.
Post by: chrisgixer on 22 August 2014, 20:43:12
If the idler has any flex in it, its shite. So that answers that one re Febi idlers.
Prevailing methodology on oof, don't by pattern parts. Or pay two or three times over, plus tyre wear.
There is Zero flex in a gm idler arm. While I agree the price is expensive, it's the only reliable part for idler arms. The Allgerman ones have flex from new. There should be none. None at all. If it has flex, return it.
Post by: chrisgixer on 22 August 2014, 20:44:29
*cough*yes there is*coughcough*
....er, well, a rubber sleeve type thing anyway.
Post by: drinksoptional on 22 August 2014, 20:46:50
Think that's issue with mine can feel movement when going over bumps the ball joints n wishbone fine can feel movment when jack it up. Just bought two part worns as both front insides were showing the white stripes they That bald and didn't want three points or spin off the road so changed pronto. Will be ordering one myself then get tracking done as it pulls to left. Then get new fronts for winter I i don't get welding on Isuzu finished
Post by: X30XE on 22 August 2014, 20:51:23
There is Zero flex in a gm idler arm....
...when it's in the packet / just fitted to the car.  ;)  The one I took off the other week had plenty  :D
Although I do accept your point re: pattern.
Post by: chrisgixer on 22 August 2014, 20:51:34
Of course you mean full geometric set up, rather than tracking. Tracking/toe setting can be spot on, yet it can still pull due to camber or castor errors.
Post by: X30XE on 22 August 2014, 20:51:55
Then call me David Blunkett.  :)
Post by: chrisgixer on 22 August 2014, 20:57:09
If you grab the road wheel at 3/9oclock and rock it in and outboard, while watching the idler through the wheel arch, and the idler moves up and down, its fubar. You should get over 100k from a gm idler.
Buy cheap, buy twice. Then moan about it. ::) :P
Post by: drinksoptional on 22 August 2014, 20:59:16
Yeah see a few post that you need to get a full set up done on these . Yeah will need to find somewhere up here that can do the full set up think someone said ATS. I have decided will keep the car a few years so with investing in. Plus save on mpg n tyres getting it done right
Post by: X30XE on 22 August 2014, 21:09:54
I quite agree; with should being the operative word! This GM one was Donald Ducked at 71k mind, although I've no idea if it's spent it's life going over pincushion speed bumps  :-\
Post by: serek on 22 August 2014, 23:32:41
just replace my idler with first line one and must say its shit,
 what sort of money they are from vx?
Post by: 05omegav6 on 23 August 2014, 01:52:47
Could have told you that for free ::) about £80 for new GM :y
Post by: 05omegav6 on 23 August 2014, 01:55:45
Don't forget your car was built at least 11 years ago, and unless you have owned it from new, there could be any number of reasons why it has failed... Expect the next 25-40k to be spent replacing things... ::)
Post by: chrisgixer on 23 August 2014, 05:15:24
They are just over £100 retail. £90 odd trade with tc.
Yep, I know. But they are the only reliable part. Fit one and you can tell it it works better the moment you torque it up to 60nm, as it does up and clicks off as it should, rock solid no play.
Pattern ones, ESP the lemforder, do it up to 60nm and it clicks off, but you know its not tight. 70nm, still not tight there's play, 80, 90, 100 still not tight. 110nm you realise its a pointless exercise and should of bought gm, as this one has play at 110nm from new.
Post by: chrisgixer on 23 August 2014, 05:17:02
Face lifts have a heat shield to protect it from the pre cat, heat probably doesn't help the rubber insert.
Post by: TheBoy on 23 August 2014, 09:55:27
If you ring up allgerman and ask for Jason, state you are a member of Omegaowners, you will get discount :y
However, the once good lemforder idlers have, like their wishbones, dropped dramatically in quality, and I can't recommend them. No personal experience of the Febi idlers.
Post by: Tony H on 30 August 2014, 16:02:21
Thanks for the "heads up" T.B. spoke to Jason who is the owner he answered the phone personally top bloke. very helpful efficient service. ordered the part received it in less than 24 hours and got 10% discount for being an OOF member  :y
