Omega Help Area => Omega General Help => Topic started by: dbug on 01 September 2014, 01:29:56
Title: Front Suspension
Post by: dbug on 01 September 2014, 01:29:56
For 2003 2.6V6 Estate - anybody got part no. for front top suspension bearing/mount ?
How long to swap?
Thanks
Title: Re: Front Suspension
Post by: TheBoy on 01 September 2014, 14:48:24
About an hour per side, esp if you have a spare set of hands.
You will disturb front camber in the process
Post by: henryd on 01 September 2014, 15:32:08
If split at lower balljoint and strut removed with hub complete it shouldn't should it ? ???
Post by: dbug on 01 September 2014, 23:03:00
OK thanks - your comment noted Henry :y
Anyone got part no/nos of required items - looks to me like a large rubber bush and a bearing.
Post by: 05omegav6 on 01 September 2014, 23:23:01
This might help...
Caveat emptor (http://www.ebay.co.uk/itm/Vauxhall-Omega-B-Carlton-senator-B-Top-Suspension-Mounting-front-90288206-NEW-/251498953149?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a8e8179bd) :y
Pedders/Monkfish do a heavy duty one and a poly alternative for the Monaro, dimensionally the same :y
ATP on ebay.de probably do a reasonably priced pattern one :y At £7 the one I linked to above is probably made of cheese ::)
Post by: Sir Tigger KC on 02 September 2014, 01:06:01
I bought and fitted a set of Lemforder top mounts from AllGermanParts recently for about £40ish but that included the bearing as well.  :y
About the same time Gixer had a set from Pedders which were a bit more expensive about £50-60 I think.  :-\
Post by: YZ250 on 02 September 2014, 02:23:52
The Vauxhall mounts are 90288206, but are expensive. I got quoted £68 each back in 2011. Lemforders were about £50 a pair from ECP a few months back.
As you say, the bush is essentially in two parts, an upper and lower bush with a bearing in the middle.  :y
Post by: YZ250 on 02 September 2014, 04:37:04
This might help...
Sorry Al, I didn't open the link until I'd posted, otherwise I'd have seen that the part number was in your link.   :-[
