Omega Help Area => Omega General Help => Topic started by: omega2018 on 04 September 2014, 02:12:41
ive got 2 new front discs to fit. dont want them to rust like the insides of the old ones so im thinking of spray painting them with hycote very temp paint.
question is do I spray the whole disk or am i supposed to mask off the contact area? masking will be a chore plus i suspect it is the areas just on the edge of the contact zone that start the rust so they need the paint most. the v high temp paint is not oil based so should just scrape off the contact area in first use and not contaminate the pads shouldn't it? assuming i spray it lightly?
i see the few pre painted discs like the black high gloss mtecs come painted all over
(http://www.mtec-uk.com/ebay_resources/listing_test/images/mtec_ebay_black_edition_before_after.jpg).
doubtless that is some fancy special coating.
if the advice is absolutely not to spray the contact area i suppose i could spray it and then remove it with some temporary fine sandpaper between the pads and disc for a few spins.
I wouldn't paint the contact areas at all, just the edges and the mounting bell.
Actually, if I were that concerned about discs appearance, I would buy coated ones and forget about them.
The Pagid discs on the rear of my car are only just starting to discolour after 3 years, which is good enough for me
thanks my rears are fine it is just the insides of the front. seems to be a common problem and defo not cosmetic. being inboard cosmetic appearance would not be an issue but anyway im not sure you can see anything on a front disc except the contact area.
I set mine up placed on an old wheel bearing on a bench spin the disc slowly as required and spray the vented edges, then the centres.
Some very slight over spray on the contact area won't hurt.
...and it's nothing at all to do with appearance. As said the inboard outer edge of the front discs will rust away on the swept area otherwise. Limiting the life of the discs.
Worth buying pre painted though, although the Gm front axle set is hard to beat on price, but are not painted.
Painted or not seems to be down to whoever made the discs... Vectra kits are painted the way Chris suggests, Mercedes disc are fully painted and the pads soon clear the contact area :y
Yes, I don't see an issue, degrease well with thinners or similar and then slap some high temperature paint on and job done.
Have taken to painting mine now for the same reasons.
The Pagid discs fitted to Mrs VXL's Alhambra were coated already (no need to degrease according to the instructions) and they are holding up so far.
Have you tried painting on GM discs, and if so, did it cure the inner face problem?
Yes, but I swapped them for ebc and painted those as well. The ebc have reached the end of their wear, and are in danger of going on past the minimum wear point without encountering the judder and loss of performance that the rust on the outer edge of the inboard face induces on gm discs.
Sadly not the answer your looking for.
But... To be more relevant....the gm discs did go rusty, but only did so after a year. I'm fairly certain that year, at my mileage at least, is enough to wear the discs out before the rusty inner edge gets to them. There by getting more mileage out of the discs.
I can assure you its not an appearance thing, in that I would prefer to keep the nice shiny finish of the originals, if at all possible. Shame they don't do a clear heat proof lacquer. :(
Having said that, they grey paint is far better looking than shitty rust brown.
Try it. It can't possibly do any harm, and can only add life to the discs. As the rust gets them before they wear out ime.
Ta. The next set I'll do. I just didn't want to be gay if it didn't help.
Too late ;D
Ps. Don't use the stuff Halfords sell. Its sh.. ...not very good.
...well, assuming the fact it washes off with brake cleaner is bad. Or maybe that's unfair. Brake cleaner is quite fierce, I suppose. :-\
Doesn't work on tree sap/baked bird poo... ::)
Seconded. "High temperature enamel". Painted the cam cover on the Westfield with that. First time it got hot, half of the paint fell off. Don't think it's going to be much use on a brake disk! ;D
The paint on both the GM discs for the Vectra C and Mercedes discs are painted with a fine grey paint which does rub off the disc with brake cleaner and a bit of elbow grease, almost looks like primer :-\
Painting brake discs. ;D ;D ;D
They don't cost a lot - £100 an axle every 5 years @ 10,000 a year. Really?
Yes really! The rust breaks off in chunks and can catch you unawares. Quite easily. It is not a cost issue, or an appearance issue, but a braking performance issue.
So yes, REALLY !
So yes, REALLY !
So you have found a paint which will happily sit on a metal surface and endure the massive heat fluctuations that a brake disc will sustain?
I'm not a very quick driver but even I know that the Omega standard discs, callipers and pads are pathetic for the weight of the car. They get smoking hot on occasions (I live near the A4174, Avon Ring Road) Roundabout after roundabout.
I really want to be proven wrong (no doubt I will be) but a squirt of some manifold paint on the fins will make bugger all difference - How do you get deep inside the disc? How are you applying this rather 'thick' paint?
Sorry, I can't see it.
So yes, REALLY !
I'm not bothered if you see it or not. :)
It is effectively that. It is calleda Dacromet coating and a lot of manufacturers use it when the brakes are going to be behind wheels with lots of spaces between the spokes. Ford were doing it about 15-20 years or so ago.
Some details on the website below
http://www.nofmetalcoatings.com/europe/en/coatings/dacromet/dacromet.xhtml
Dacromet contained "hexavalent chromium Cr6" so it was replaced by Geomet http://www.anochrome.com/wp-content/uploads/2012/01/NOF.pdf (http://www.anochrome.com/wp-content/uploads/2012/01/NOF.pdf) in 2007.
Does anyone know if it is available for DIY use? it looks ideal for prolonging the life of steel fasteners on old cars, motorbikes (& preserved railways?).
I'm using Hycote very high temperature paint: "superb adhesion to bare steel" "temperature resistant up to 650C". £5 for a 400ml can inc delivery.
I don't care much about the innards, discs rust from the edges to the contact surface in my experience and it is the contact surface rust that is the problem.
5yrs or 50K :o
I usually managed 2yrs or 20k, max. Admittedly, usually due to inside edge corrosion...
If paint stops the corrosion, I'm happy with that :). I guess any high temp paint, such as that designed for calipers, will withstand the abuse ;)
5yrs or 50K :o
Are you talking to yourself again Mr TB, or is that a real person your quoting? ;D
I reckon some nice bright blue sparkly paint will look the business on either of TBs cars ;D
5yrs or 50K :o
Nope, me no understumble....?
5yrs or 50K :o
Ah the old "found guilty pretend fuddelment" line. I see ;D
