Omega Help Area => Omega General Help => Topic started by: teddington man on 17 September 2014, 06:50:56
Title: Omega manifold
Post by: teddington man on 17 September 2014, 06:50:56
Hi all just a quick one can I fit a manifold from a 2.0 16v to my 2.2 16v as mine is cracked
Title: Re: Omega manifold
Post by: minifreek on 17 September 2014, 07:23:45
No.... totally different engines...
You can - however - weld the crack on the manifold... I know it can be done, as I'v done it :)
Post by: Marks DTM Calib on 17 September 2014, 08:04:37
Yes you can fit the 2.0 manifold but, it does have extra holes for air injection etc. which would need to be blocked.
And yes you can weld them, not easy as its cast but do able.
Post by: teddington man on 21 September 2014, 14:03:35
Well today I got the old cracked manifold off. Not only is it cracked on the outside it also has a massive crack inside the manifold port so repairing it is defo out of the question
Post by: minifreek on 21 September 2014, 15:16:21
So the manifold from a X20XEV will fit a Z22SE....?
OR
Is the 2.2 in an Omega the X22XEV found in the Frontera's and Sintra's...?
Post by: Temetsy on 21 September 2014, 15:34:43
No, it's the Z22SE found in omegas. IIRC the base engine is the same x20xev that pfl omegas have.
Post by: teddington man on 21 September 2014, 16:14:10
If I buy a new manifold should I go with genuine or just get an after market one
Post by: Temetsy on 21 September 2014, 16:17:23
I'd think both'll do, or you can buy a tune-up manifold for some awesome extra 5hp :D
Post by: RobG on 21 September 2014, 16:20:28
Z22XE
Post by: teddington man on 21 September 2014, 16:24:00
I think that will cost alot more lol
Post by: Temetsy on 21 September 2014, 17:24:39
Z22XE
Thanks for correcting, too many twentytwos for tired mind ::D
Post by: 4x4 on 21 September 2014, 17:49:42
Frontera 2.2 is same engine as omega,cambelt driven,and we have the same problems with manifold.
