Chat Area => General Discussion Area => Topic started by: Taxi_Driver on 29 September 2014, 19:04:29
Title: Bosch Washing Machine
Post by: Taxi_Driver on 29 September 2014, 19:04:29
My Mums, probably about 5 years old....
She's determined she needs a new one.....so she shall get one...no probs..
But the problem with it, is it keeps tripping the ELCB....apparently is fine spin drying...just on main wash it trips the breaker.
I'm thinking this is most likely the heater element doing this....i cannot understand anything else doing it....as its ok on spin drying.... :-\
So instead of letting Curry's (most likely) take it away to the tip.....do you reckon its worth me taking it away instead and replacing the heater element....see if it fixes it....then keep it as a spare for my old 15yo Bosch (or swap it over)
Anything else likely to cause the ELCB to trip??  :-\
Title: Re: Bosch Washing Machine
Post by: Kevin Wood on 29 September 2014, 19:16:16
Yep, most likely the element. Worth saving for the sake of a £15 part, especially as many newer machines are getting to be practically throw-away items that are impossible to repair. :y
Worth having a look inside to see if there's any evidence of water leakage on to any electrics first. The motor being a prime example, if it's slung under the drum as most are.
There's often a mains filter on the mains inlet too, Sometimes the capacitors in them can go leaky and trip the breaker. Should be easy to isolate the fault with a megger.
(Currently awaiting bits to get ours back working) >:(
Post by: tigers_gonads on 29 September 2014, 19:21:44
RCD / ELCB tripping is caused by a neutral / earth leakage.
If as you say it is okay on spin but trips on the heat / wash cycle then yup, i'd be looking at the heater element as kev says
One question though, is the programmer mechanical or digital ?
Sometimes, the mechanical contacts can wear and start to arc which will definitely trip a old ELCB so beware  ;)
As for fixing it up, all depends on the price of the element tbh  :-\
Post by: flyer 0712 on 29 September 2014, 19:28:12
My daughters Bosch washing machine recently needed the drum bearing replacing so it had to be taken apart..a bit time consuming but an easy job..in doing so we removed the heater element  just to inspect it while it was there in front of us,only to find it was caked in crap and lime scale even though she uses a very well known lime scale remover that is supposed to stop the lime scale..what a complete load of crap and waste of money...Anyway I said at the time if you ever have to replace the element it would be so easy,,,,If you are not sure about doing it I found a video on you tube that made it so easy to do.. :y :y
Post by: Marks DTM Calib on 29 September 2014, 21:23:10
Remember that an ELCB will trip when there is greater than a 30mA imbalance between live and neutral currents.....that could a neutral to earth fault or a live to earth fault.
Easy way to test is to disconnect the heater element and give it a run.
I cant see it being the filter or it would be tripping on spin and all sorts.  :y
Post by: Taxi_Driver on 30 September 2014, 06:13:24
Thanks for all the replies guys....sounds like its worth having a go at fixing it  :y
I can imagine disconnecting the heater causing another problem, ie wont it stop mid cycle waiting for the water to heat up and not carry on until the water does heat up  :-\
Post by: 05omegav6 on 30 September 2014, 07:55:07
Test it on its coldest setting :y
Post by: Rog on 30 September 2014, 09:18:37
I'm a firm believer that all "white goods" are designed to have a life expectancy of around five years, even "quality" brands like Bosch.  >:(
Post by: Kevin Wood on 30 September 2014, 09:22:17
Maybe, maybe not. On a lot of simpler machines the heater is just powered, in series with a thermostat, during the wash cycle and there is no provision for the timer to wait.
If you're going to disconnect the heater anyway, just check for leakage between element and earth, then you have something conclusive. If it's bad enough, you may see it with a normal multimeter on ohms. Failing that, a megger is your friend.
Post by: Kevin Wood on 30 September 2014, 09:25:27
The problem is that all (bar a couple) of the "quality" brands also now make cheap shite.
Post by: TheBoy on 30 September 2014, 19:20:19
Sssshhh, don't let my dishwasher hear that.
Oh, I forgot, its cheap shite (hotpoint) ;D
Post by: ronnyd on 01 October 2014, 00:29:22
Had a Bosch tumble dryer a few years back, a real Friday afternoon job. Continually blowing overloads etc.
Got dumped after a couple of years and now using my daughters old Electra, still goes ok, or am i tempting fate? ::)
Post by: Vamps on 01 October 2014, 00:45:08
[/quote
Post by: Vamps on 01 October 2014, 00:46:17
[/quote
That's about right in our household for washer and dryer, we have better luck with fridges x2 and freezers also x2, my very first auto washer, an Ariston, was still going strong over 10 years later when I left it in a house I moved out of.......... :-\ :-\
Post by: Vamps on 01 October 2014, 00:47:09
Sorry, not sure what went wrong there...... ::) ::)
Post by: cnj on 01 October 2014, 05:42:04
not quite sure how many "quality" products are made by beko in eastern Europe !!
Post by: Kevin Wood on 01 October 2014, 09:22:35
Well, slapped some new bearings, drum spider and element in the old Zanussi last night. Will be back in action tonight with a bit of luck. :D
Post by: Marks DTM Calib on 01 October 2014, 09:26:38
Who make the dishwashers for........Bosch  ;D ;D ;D
Post by: TheBoy on 01 October 2014, 20:54:01
Aye. In fact when I bought this one, there was a Bosch next to it, only difference was the badge and the cutlery tray.  The Hotpoint won because I could take it away the same day.
Post by: Taxi_Driver on 24 May 2015, 18:00:54
Blimey, has it really been this long that my mums old washing machine has been sitting in her garage  ::)  ;D
Anyway I got around to replacing the heater element this afternoon...
It was so lime scaled up when I took it out.....obviously my mum hasn't been using the Calgon tabs that were sat on the top of machine when it was replaced  ::)
I tested the old element, sort of, as I don't have a mega....I used my multimeter in ohms (diode mode) which I think puts a few more volts down the probes....less than 2ohms between live and earth  .... new element read open circuit.
Well worth doing, as long it has fixed it and also doesn't now leak, as I took it apart and rebuilt it  ::) ;D
(Front side of the machine had to come off to get to the element)
£10 odd for a new element  :y :)
I wonder how long it will take for the machine to move from my mums garage to my kitchen  ::) ;D
Post by: ronnyd on 24 May 2015, 19:40:26
At the rate you,ve been going so far the damn thing will rust away first. ;)
Post by: Taxi_Driver on 31 May 2015, 19:18:22
It moved today  :y
Now installed in my kitchen....
Put some Dr Beckmanns Washing Machine Cleaner thro it at 60C ....spose to get rid of limescale and grunge....
Now it doing another wash with Dr Beckmanns deep clean....at 90C which is spose to kill 99.9% of germs
Worth doing I think seeing as how long its sat and it proves the heater I replaced is working and no leaks after I repaired it  :y ;D
