Chat Area => General Car Chat => Topic started by: 4x4 on 01 November 2014, 17:20:33
Where is the brakelight switch on these cars ,as swmbo car the brake lights are on constantly.
Mr Emd is the man to ask. He loves Pugs. :)
above the passenger's feet .,........... she's had a big footed clumsy bugger as a passenger that has kicked the switch off hence the lights on all the time :y :y :y
Yep,my lads mate were always knocking his off :y
whilst on the subject of a Pug 206 ......
how's the fan belt tensioned? It's not an auto/sprung tensioner, but a cursory glance in the engine bay without a torch & not wishing to lie on the ground, I couldn't see how it moved. ???
Which engine Andy?
Which engine Andy?
Err? Not sure ...... my daughter's boyfriend (owner of said car) thinks it's a 1200cc ??? ??? (he's a teacher! ::))
Which engine Andy?
So petrol then,age?
I had a look earlier and theres a hole in bracket,but couldnt find switch in that area.
Which engine Andy?
So petrol then,age?
I forgot to look .... I've just text her to find out :-[ but the layout is the top left
(http://i248.photobucket.com/albums/gg198/JamieRF/pugbelt.jpg)
If you found the hole the switch will be there somewhere
Which engine Andy?
So petrol then,age?
Two 6mm Allen bolts hold tensioner in place on a bracket with another Allen key at the bottom pointing straight up to adjust tension
Thanks Henry ...... as said, I wasn't dressed for crawling under & I couldn't see properly from above. It's already cost me a headlight bulb, he was going to take it to a garage to change it! Even worse, he mention taking it to Halfords! :o ;D ;D
....and you are going to let this man marry your 'little girl'...... ;D ;D ;D
;D ;D ;D
....and you are going to let this quite obviously homosexual, french car loving gobshite marry your 'little girl'...... ;D ;D ;D
Fixxored
Fixxored
He's not bad ........ better than the last one or the one before that ::) ::)
Give him your tool kit and tell him you need a cambelt change. If he seems eager, he's a keeper. If he starts crying, let your daughter do it! :P
I think having Emily do it would be a better bet! :y :y :y
PS A R320 has a chain ;)
