Omega Help Area => Omega General Help => Topic started by: Impact Pete on 06 November 2014, 10:35:47
Title: P0420 fault code
Post by: Impact Pete on 06 November 2014, 10:35:47
Engine light is on and following codes are flashing
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
I have a leak between the mid exhaust box and the back box could this effect the above codes?
Title: Re: P0420 fault code
Post by: Marks DTM Calib on 06 November 2014, 10:38:59
Nope, pre-cats are getting tired.
The fix is to relocate the second O2 sensor to behind the main cat
Post by: Impact Pete on 06 November 2014, 10:41:50
ok so just a coincidence then with the leak ive had a few weeks.
re moving sensor will the engine light clear after the set amount of clean starts or will it need clearing?
Post by: Marks DTM Calib on 06 November 2014, 10:52:15
It will clear it self
I might be able to spare an hour and fit new bosses for you if needed
Post by: Impact Pete on 06 November 2014, 19:05:10
hi very kind will get back to you once I get to have a proper look
thank you
Post by: Impact Pete on 15 November 2014, 14:11:44
Thought I would update that the engine light went out a few days later so decided not to do anything!
Post by: VXL V6 on 15 November 2014, 14:16:54
It'll come back on again more and more!
Post by: chrisgixer on 15 November 2014, 16:52:04
Pre cats will get more and more tired as the miles roll by. So the light will stay on for longer and longer periods. Until it's on permenamtly.
Keeping them hot is key, to a point. So lots of pootling in traffic will usually see the light on more often than a motorway journey. And more in turn than ragging the t*ts off it.
What ever you do though, do NOT be tempted to replace the enire cat. See the guide on a permenant fix, muuuuch cheaper. :y
Post by: Impact Pete on 08 May 2015, 20:07:35
I thought I would update on this as it's now May and the lights still off and the codes are clear  ::)
Post by: chrisgixer on 08 May 2015, 20:14:13
Give it time. :)
Post by: Impact Pete on 08 May 2015, 20:17:11
Give it time. :)
6 months is time oh all yee of little faith, this is not the first time an issue has disappeared on my omega without any maintainance!  ;D
Post by: biggriffin on 08 May 2015, 20:40:38
Might be worth giving it the shell Italian tune up. :y
Post by: The Sheriff on 08 May 2015, 20:43:01
Bulb's gone. ;D
Post by: 05omegav6 on 08 May 2015, 21:03:06
Bulb's gone. ;D
Ne'er a truer word said in jest... ::)
Post by: Impact Pete on 08 May 2015, 21:04:59
Bulb's gone. ;D
wouldn't stop codes showing though  :)
