Omega Help Area => Omega General Help => Topic started by: X30XE on 10 November 2014, 18:00:06
Title: 3.2 - P1890 , P1781*, P0706*
Post by: X30XE on 10 November 2014, 18:00:06
Started the car this morning, starts running rough straight away, flashing EML.  Great.
Fault codes from scantool :
P1890
P1781* (pending)
P0706* (pending)
None of which seem to appear in the maintenance section list of Y32SE codes.
Any suggestions ?
Car has already had 2 x coil packs, cam gaskets, 6 x plugs
Crank sensor?
Title: Re: 3.2 - P1890 , P1781*, P0706*
Post by: TheBoy on 10 November 2014, 18:08:02
Autobox selector switch playing up?
Post by: X30XE on 10 November 2014, 18:20:26
Ya recon? Wouldn't that cause it to fail to turn over?  :-\
Post by: TheBoy on 10 November 2014, 18:27:59
The 17xx and 18xx are CAN errors. This is a sign one of the ECUs on the CANBUS is either saying something unexpected, or not responding (or responding in an expected manor). This itself is usually when one of the CANBUS ECUs is in some form of error handling. The 0706 is a Range switch, and the only useful code.  Worth reading TCM and ABS anyway.
Which EML is flashing (3.2 has 2), and what are the symptoms (turning over, not firing? Starting, but running like a sack of shite?)
With the limited info given, I'd start with known issues first (ie, the codes you got) ;)
Post by: TheBoy on 10 November 2014, 18:28:38
Obviously, flashing EML with ign on, but not starting, is immobiliser
Post by: X30XE on 10 November 2014, 18:38:31
As per first post, it starts but runs like it's missing, similar to when one of the coils had bit the dust.  It will rev. I didn't even bother trying to move the car this morning, just gave it the f stamp, turned it off and pulled the codes on the laptop.
Car was fine on Saturday.  ::)
Post by: TheBoy on 10 November 2014, 18:39:58
OK, so check out range switch first then. Nice easy check.
Also, clear all codes (in engine, gearbox and ABS if you have that capability), so we know where we stand :y
Post by: X30XE on 10 November 2014, 19:05:09
That's going to have to wait til at least the weekend.  :(
Just been out and started it up, and other than a bit of hunting at idle +/- 30rpm it's running ok whilst sat in Park.  Selected all gears fine.  Cleared all codes, only the two rear o2 sensors reappeared (which were keeping the engine light on before).
Given that I didn't even make it out of park this morning and the engine was running shit is it still likely to be the switch?
Think Ellie is going to be visiting Serek's naughty step again soon >:(. (Aka second home)   ::)
Post by: TheBoy on 10 November 2014, 19:23:01
The TCM (and ABS unit) have the option to ask the engine for "reduced torque", which basically cuts cylinders.
If it plays up again, immediately check the LEDs near gearstick, see if all on, or flashing. If so, you've found a likely cause.
Additionally, now you have cleared codes, keep an eye on if Range Switch code comes back.
A further problem may be the trims are drifting too far (this will cause the emmissions EML to flash as well), which will make it run like a bag of nails. Clearly codes reset trims. So before you clear codes next time, read the trim values.  Trim faults that far out, though, normally give misfire codes as well.
Post by: X30XE on 10 November 2014, 19:40:45
I see.  I shall monitor it. Thanks  :y
Only the check engine light flashes, although with 3month old primary o2 sensors, 2 month old coils and plugs i'd be narked off if it couldn't fuel correctly.  (And on any other day it runs just fine).
Post by: TheBoy on 10 November 2014, 19:51:14
Far more involved in fuelling ;)
But lets monitor. After you've used it for a couple of journeys, let us know what the LTFT for each bank reads :y
Post by: X30XE on 16 November 2014, 14:49:28
In the interests of completeness...
Several journeys and a couple of hundred miles later and fault has not reoccured or logged any codes.  :D
LTFT Bank 1 = 1.6%
LTFT Blank 2 = 0.0%
Post by: VXL V6 on 16 November 2014, 15:03:47
What brand of O2 sensors did you use?
Post by: X30XE on 18 November 2014, 21:58:58
Cambiare (sp?) ones that came with the car when I bought it. Why?
Post by: TheBoy on 19 November 2014, 18:34:52
LTFT bank 1 doesn't look good. Check for airleaks around the ICV and vac.
Post by: chrisgixer on 19 November 2014, 18:39:01
...on a 3.2?
Post by: TheBoy on 19 November 2014, 18:44:13
...on a 3.2?
Sorry, looked at OPs name, not car ;D
Ignore the ICV bit, but still look for airleaks that side, eg vac
