Chat Area => General Car Chat => Topic started by: chrisgixer on 12 November 2014, 18:57:29
...are they serviceable in any way?
Mine works ok but the whats it called? Not one touch, but the press without engaging indicator before it clicks, part of the indicator stalk movement sticks and won't return on its own. And flashing high beam doesn't seem to actually turn the lights on simetimes.
Or is it a case of just buying a new one?
WD40. Go on, try it. You know you want to.
NUUURSE! Put him back in gen chat please, he's pestering the normal people again.
Instead of using it to lubricate your arsehole, try it on the indicator stalk. Go on. ;D ;D
Is that what BMW's are lacking? ::)
I quite like fish and chips with mushy peas.....
About £40 from dealer (that was 2 or 3 years ago though).
I have taken them apart before - fairly simple - but the 2 I've had fail were not really repairable one had burned contacts and the other had a weak (springy bit) contact).
These fantasies of yours are getting out of control again.
NUUURSE! ....give him his meds while your at it ::)
Did you try WD 40? Or custard?
I personally tried swearing a lot.
WD40 fixes everything. I keep a can in my pocket to amaze people by making switches work and stopping things squeaking. :y
Don't put WD on switches, you'll start a fire , you oppsing eejit ;D
Or give TB ideas, one or the other ;D
No. Because WD40 stops them arcing. It's wonderful stuff. Have you tried it yet, and will you admit it if it works? ;D
look, people in Hun.... No never mind.
It was something that I was getting around to for 10 yrs ........ but never did. Mine used to arc on the momentary push if I didn't give it a reasonable push
