Omega Help Area => Omega Electrical and Audio Help => Topic started by: stu24v on 03 December 2014, 20:37:39
Title: Heated front seats
Post by: stu24v on 03 December 2014, 20:37:39
Put heated seats on this morning after a few minutes got burning smell got home and found the leg extension part of the seat at fault . Could see smoke coming from the centre of the seat any ideas on fault or repair .cheers all
Title: Re: Heated front seats
Post by: 05omegav6 on 03 December 2014, 20:40:41
Strip the seat. Locate and bypass the burnt bit(s). Test. Refit :y
Or remove the fuse ::)
Post by: chrisgixer on 03 December 2014, 20:50:33
Presume the seats are mv6?
Can the leg extensions bit be looped out / disconnected and the wires in the seat re joined?
Do I recall some plugs on the leg extension bit?
Post by: 05omegav6 on 03 December 2014, 20:58:11
You could well be correct... not gotten that involved with Omega seats tbh, but certainly stands to reason that the extensions would contain a circuit, er, extension ::)
Thinking about it, I'm sure there's an extra plug in the seat heater loom for that very reason, mentioned in the wiring diagrams too :y
Post by: stu24v on 08 December 2014, 20:33:05
Thanks for replying il try some off them . Car getting old like me ha ha  :y
Post by: TheBoy on 08 December 2014, 20:35:48
I'd be wary just bridging the leg extension out, as the resistance of the seat circuit will be less than designed, and you could well burn out the rest of it fairly quickly.
The seat extension is fairly easy to strip, and get to the failed bit of element.
