Omega Help Area => Omega Electrical and Audio Help => Topic started by: Drewomega on 07 January 2015, 10:52:55
Title: Reading Lights On
Post by: Drewomega on 07 January 2015, 10:52:55
Hi Guys,
A happy new year to one and all.  :y
After being away for 4 months the Omega started up first time, no problems.
However, last night I jumped out of the car and the reading light failed to go out. There are four lamps in the unit, I faffed around with it and as it was dark and raining I disconnected the battery. This morning I reconnected battery and the lights went back on. It is the back 2 lights in the unit that are on.
Anybody any ideas?
Thanks in advance guys.
Title: Re: Reading Lights On
Post by: 05omegav6 on 07 January 2015, 11:04:34
Headlight switch not pulled out slightly :-\
Post by: Drewomega on 07 January 2015, 11:28:04
Hi Al. Just tried that, still the same. I don't know which is the reading lights and which is the door lights.
Post by: 05omegav6 on 07 January 2015, 12:14:21
Reading lights only switch on using the buttons on the light unit :y
Post by: Drewomega on 07 January 2015, 12:42:26
Just plugged unit back in and the reading/map light switches do not work either. Which 2 lamps are the courtesy ones and which are the reading map lamps?
Post by: RobG on 07 January 2015, 12:44:01
Reading ones are the small spots
Post by: Andy B on 07 January 2015, 12:52:35
.... and which is the door lights.
the lamps that come on when you open the door  ::)
Post by: Drewomega on 07 January 2015, 13:00:52
LOL! Right! I have managed to get the reading lights to work and they are the front 2 lamps. So the back 2 lamps and the spots must be the courtesy lights. It is the back 2 lights I am having the problem with staying on.
Post by: RobG on 07 January 2015, 13:20:20
The manual switch on the rear lights has three positions, OFF, ON, and ON when door opens.
Post by: Andy B on 07 January 2015, 14:15:25
he means the rear lamps in the front courtesy light ........ not the lamps in the rear of the car .....  I think  :-\
Post by: Drewomega on 07 January 2015, 14:35:37
Correct AndyB. A cluster of 4 lamps are in the front courtesy light with I think a motion sensor. It is the back 2 lamps in the cluster that are staying on.
Post by: Drewomega on 07 January 2015, 17:44:17
(http://i439.photobucket.com/albums/qq119/drooscott/Untitled_zpsdcb00e30.jpg)
These are the lamps that are staying on all the time. I have since taken the lamps out to save my battery.
Any suggestions as to the problem would be much appreciated.  :y
Post by: Andy B on 07 January 2015, 19:00:53
....  with I think a motion sensor.  ....
the silver bit in the middle? That's a microphone for a phone  ;)
Sorry, can't help with the courtesy lights staying on other than a duff light unit  :-\
Post by: RobG on 07 January 2015, 19:13:33
Have you tried lightly cleaning the PCB with switch cleaner, or could possibly be a dodgy switch on driver`s door pillar
Post by: 05omegav6 on 07 January 2015, 19:15:25
Sorry, can't help with the courtesy lights staying on other than a duff head light switch   :-\
Fixed :y
If the reading lights work, then there's only one thing left...
Post by: RobG on 07 January 2015, 19:16:31
Fixed :y
Easy enough to eliminate that
Post by: 05omegav6 on 07 January 2015, 19:17:47
Indeed, which should see the issue sorted ;)
Post by: Drewomega on 07 January 2015, 19:58:25
Thanks guys! Wow! OOF at it's best. :y :y :y :y :y
Post by: hotel21 on 08 January 2015, 13:00:06
Currently going through a similar scenario myself.   My probs started the same way with interior light staying on, irrespective of door open or closed or headlamp switch in/out. Battery would go flat and not hold a charge then when on a run, got disco dash lights and dead Rev counter/speedo when driving. And drivers electric seat failed (passenger side still works though).
Looks like a combination of knacked battery and equally knacked alternator.
Weather permitting, will resolve at the weekend.  :)
