Chat Area => General Car Chat => Topic started by: Field Marshal Dr. Opti on 07 January 2015, 16:02:09
Title: Inner tubes in tubeless tyres.
Post by: Field Marshal Dr. Opti on 07 January 2015, 16:02:09
Would this present any problems?
Title: Re: Inner tubes in tubeless tyres.
Post by: henryd on 07 January 2015, 16:15:26
I know that tyre fitters aren't allowed to fit them anymore but not sure if thats law or there idea
Post by: The Sheriff on 07 January 2015, 16:22:28
On a bicycle? Shouldn't think so.
I wish Chrisgixer was here to answer difficult questions such as these.
I would ask him: my tyres keep losing pressure. I have purchased some cheap Chinese valves but they are, unsurprisingly, crap and didn't cure the problem. I thought about getting the wheel rims cleaned, thought for ages and ages, but decided I am too tight. What should I do? Stick inner tubes in? ;D
Post by: JasonH on 07 January 2015, 16:26:36
It's not legal because it's not safe. The problem is the inside of a tubeless tyre isn't smooth. It will abrade the inner tube until it goes pop. A friend had a very nasty accident on a motorbike because he did this and the front tyre went pop at high speed.
Post by: 05omegav6 on 07 January 2015, 16:34:38
Completely, totally and utterly illegal. And with good reason. Don't even go there...
Post by: Sir Tigger KC on 07 January 2015, 16:39:04
 :D  ;D
Post by: Field Marshal Dr. Opti on 07 January 2015, 16:41:17
I'm losing about five pounds each day.
That's 5 PSI and not £5.....or if on a diet 5LB.
Just though I'd clarify for the thickies amongst you. ;D
Post by: Field Marshal Dr. Opti on 07 January 2015, 16:43:12
 :D  ;D
Doesn't work. Not for long anyway, smartarse. :P :P :P
Post by: 05omegav6 on 07 January 2015, 16:44:25
Sounds like you have a puncture ::)
Post by: Field Marshal Dr. Opti on 07 January 2015, 16:48:44
...on all four wheels? ;)
I'm spending more and more time with the foot pump. :-\
I'm tempted to buy a two year old Daewoo......then I won't need to concern myself with age related problems. :)
Post by: 05omegav6 on 07 January 2015, 16:51:48
Actually, given TBs recent experience, be prudent to check the inner sidewalls for cracking :-\
Post by: Sir Tigger KC on 07 January 2015, 16:53:49
Cool! I'll look forward to your next car purchase then M'lud, as I could do with a laugh!!  :P  :D  ;D
Post by: Field Marshal Dr. Opti on 07 January 2015, 16:57:35
Don't laugh, Sir Tig. A Daewoo is a real 'pussy puller'.....just ask STMO. :)
Post by: Sir Tigger KC on 07 January 2015, 17:04:53
There was an Orlando in Lidl's car park today....  ::)
Post by: Kevin Wood on 07 January 2015, 17:09:21
Broken down on the way to Waitrose, had it?  :D
Post by: Field Marshal Dr. Opti on 07 January 2015, 17:13:14
Was it dripping with scantily clad beauties?... ;)
Or just dripping oil and coolant. ;D
Post by: Kevin Wood on 07 January 2015, 17:14:25
Was it dripping with scantily clad beauties wee?... ;)
Or just dripping oil. ;D
Fixed that for you. :y
Post by: Sir Tigger KC on 07 January 2015, 17:55:10
No, it wouldn't have fitted in at the local Waitrose, where it's either Old Dear's Nissan Micra's or Yummy Mummies Range Rover's!  ::)
Post by: The Sheriff on 07 January 2015, 18:03:21
You may mock. But you won't find me asking questions about which adhesive I should use to hold my roman chariot of a car together.  ;D
Post by: Sir Tigger KC on 07 January 2015, 18:19:30
Actually, I thought if I ever needed a 'Mummy Bus' (Unlikely, but you never know  ::)) I'd go for an Orlando over the Zafira.  :y
Post by: Field Marshal Dr. Opti on 07 January 2015, 18:27:24
If you can pick an Orlando  up for buttons, then yes. :D :y
Post by: The Sheriff on 07 January 2015, 18:29:38
There are no more new ones, so you'd have to have a used one. If you're seriously considering one, be aware that spares are becoming harder to find. A guy on the forum had to pay a dealer £24 for a rear wiper...outrageous but no choice. No one will bother setting up the tooling to make cheaper parts, there aren't enough of them about.
I'd go for the zafira, Tigger, cheap as chips and easy to maintain. The fact that you're considering a people carrier means you're looking for something to work for you rather than something to look at. Zafira parts and repairs are readily available and hassle free is what you need.
The orlando has parts which are not in common with the zafira, like the climate control system. If something like that goes wrong, it would be really difficult to find someone to repair it.
Just an honest opinion, I don't want you to come unstuck so I can sing the praises of my car, although I do like it.
Post by: Field Marshal Dr. Opti on 07 January 2015, 18:34:50
Piss taking apart I actually like the look of the Orlando. Enough to buy one should the price be right?......I'm not sure about that. :y
Post by: The Sheriff on 07 January 2015, 18:51:17
Mine's due it's first MOT next month, let's wait and see.
Post by: Field Marshal Dr. Opti on 07 January 2015, 19:26:39
It's usually about MOT number three that expensive demons first show themselves. The first MOT will be (should be) a walk in the park. :y
Post by: Sir Tigger KC on 07 January 2015, 21:08:20
Thanks for your concern and advice Uncle STMO, but I did say IF I ever needed a Mummy Bus....  ;)  :y
