Omega Help Area => Omega General Help => Topic started by: grahamff on 10 January 2015, 14:51:37
Title: Outer sill trims
Post by: grahamff on 10 January 2015, 14:51:37
Hello there,
MOT due up again this month. The last advises included the statement 'unable to check sills for corrosion as covered by trim' Is there a potential problem in this area or is there a way to remove the trims prior to the test and have a look? I cannot find any reference to this in the maintenance guides so am led to think there is not a problem??
Title: Re: Outer sill trims
Post by: Webby the Bear on 10 January 2015, 14:58:14
My understanding is the MOT man isn't allowed to undo nuts, bolts, remove trim etc. So I'd interpret that as ''I cant remove the trim but im going to cover my butt by indicating why I couldn't)
however, if you wanted to just undo the retaining screws at theend and snap the trim off to look at sills. look at both sides
Post by: TheBoy on 10 January 2015, 16:00:33
Unless you know of a problem, it can be ignored.  Many MOTers put such and adviso on as an arse covering exercise.
Post by: Magwheels on 10 January 2015, 16:43:44
As above  :y
It shows they have been looking! :)
Post by: ronnyd on 10 January 2015, 18:00:10
Yes, i have got that advisory on the MOT that i have just had, which insurance co. insisted on after it was written off as
Cat C. This is the first time in ten years of Omega ownership that i have seen that. Is it something new or what? ???
Post by: TheBoy on 11 January 2015, 18:02:58
No
