Omega Help Area => Omega General Help => Topic started by: D_Mcginty on 14 January 2015, 16:26:13
Title: 2.2DTI Still going into limp mode after EGR Valve change. ??
Post by: D_Mcginty on 14 January 2015, 16:26:13
Whilst driving home the other day my car started to jump/jerk when I would put the foot down. Seem to go away for a while until I was less than 500 yards from the house it started to get really bad while idle aswell. And then the engine management would come on and the car would cut out. Found out the egr valve would be the cause. Changed that today and it started for 10 seconds idling perfect and just cut out all of a sudden. Tryed towing it and engine management light still comes on and goes into limp mode. This car has my head fried between limp mode and not starting  :o. Really considering the box of matches and petrol can !! :D :D :'(
Title: Re: 2.2DTI Still going into limp mode after EGR Valve change. ??
Post by: 4x4 on 14 January 2015, 16:36:42
Crank sensor can cause limp mode.
Post by: D_Mcginty on 14 January 2015, 18:25:13
Would it cause it to not take any revs at all ?
Post by: VXL V6 on 14 January 2015, 20:04:14
If the crank sensor dies on a DTi the tachometer will not move and the idling will be poor.
You really need to get the codes read because 'jump / jerk' is classic fuel pump failure symptoms imho.
Post by: firemoth on 14 January 2015, 21:33:54
Fuel filter?
Post by: VXL V6 on 14 January 2015, 22:09:07
Doubtful. If you change it, make sure you do it with the engine fully warmed up, drain any water from the drain tap at the bottom and top back up with diesel magic. Once started keep the revs up a bit because it will cough a bit if any air has got in. If you can't start it then too much air has got in and you probably have to bleed the system.
Post by: Elite Pete on 15 January 2015, 11:32:23
A priming bulb is a must on the 2.2DTi :y
