Omega Help Area => Omega General Help => Topic started by: Andy A on 29 January 2015, 10:34:50
Title: Omega 2.2 petrol 2003 manual possible engine temp problem
Post by: Andy A on 29 January 2015, 10:34:50
In winter or summer time with the air-con on, should the engine temp stay fairly stable around 85 - 92, if the car is idling or doing 70mph?
As soon as I go down the motorway the temp drops from around 92 to around 65 depending on outside temp and speed.
I have noticed that all the rad fans are on when using air-con. No matter if its winter or summer. Is this normal?
Thanks
Title: Re: Omega 2.2 petrol 2003 manual possible engine temp problem
Post by: Entwood on 29 January 2015, 10:49:43
air con on the fans run continually .. totally normal.
Temp dropping at speed .. does it take a long time to warm up as well ?? If so .. thermostat stuck open .. needs a new thermostat
Post by: Andy A on 29 January 2015, 12:13:01
Yes it takes a while to warm up.
Do you know if the thermostat is separate or an all in one part with the housing?
Eurocarparts is showing both.
Thanks
Post by: RobG on 29 January 2015, 12:17:35
Get it separate Andy
Post by: Andy A on 29 January 2015, 14:02:00
Will do Rob. Will I need a new gasket?
Post by: PhilRich on 29 January 2015, 14:48:17
Ideally yes, but a thin streak of instant gasket around the original seal will do just as well if it isn't broken :y
Post by: Andy A on 29 January 2015, 16:44:39
Thanks all for your help.  :y
Post by: Twintop on 29 January 2015, 22:28:04
Ecp were doing thermostat and housing for about £5 on flebay  :y
Post by: TheBoy on 30 January 2015, 08:38:59
The 2.2 stat is piss easy to change, and even dealer gasket is cheapish. From memory, dealer price for stat is a steep £25 though :(
Don't forget to add coolant to the budget as well
Post by: Andy A on 30 January 2015, 09:29:22
Anyone know what the torque settings are for the bolts?
Is it best to replace from dealer or will any do the same job?
Thanks
Post by: PhilRich on 30 January 2015, 15:21:35
Thanks
The original bolts can be reused and the torque is 8nm iirc :-\
Post by: 05omegav6 on 30 January 2015, 16:11:34
15NM/11lbft according to the book of bloks :y
Post by: PhilRich on 30 January 2015, 18:19:37
Thanks Al, I need someone to keep me right! ;D :y
Post by: Andy A on 30 January 2015, 19:01:48
15NM it is then.
