Omega Help Area => Omega General Help => Topic started by: djmoorey on 13 February 2015, 20:53:37
Hi can someone tell me the cause of this warning coming up thanks headlamp range adjustment-headlamp light are all ok
Probably a level sensor fault .Check front wishbone n/s that arms hasnt fallen off as most likely culprit.
If you use the search facility you should be able to find Rob G's posting with pictures of what the level sensors look like .
IIRC there is also an exploded diagram of all the parts there as well
there are 2 sensors . . . 1 front . . . 1 rear both behind the wheels on N/S
Try putting . . . " HID sensor" into search :y
sorry can't do them "linky things" :-[ :-[ :-[
dead easy al :y
dead easy al :y
not for me Bigtime ;D ;D . . . I'm a total numptie on PC's :-[ :-[ But 6 strings & an amp . . . thats another story :y
Hi thanks will have a look if and when it stops raining lol.Weather i cwmbran is crap
I have had a search on the forum and found the photos of the sensor so will have a look when it stops raining cheers
Also worth having a really good look at the condition of the wiring going into the plug as does have a dendancy to perish and break given its location and exposure to dirt/water etc. :y
