Omega Help Area => Omega General Help => Topic started by: Tony H on 22 February 2015, 12:41:11
Title: Climate control problem
Post by: Tony H on 22 February 2015, 12:41:11
Hi all, as title it will only blow hot air when the unit is set on "Hi" any ideas what the cause may be?
TIA
Tony
Title: Re: Climate control problem
Post by: zirk on 22 February 2015, 12:51:34
Hi as in Hi Heat?
Post by: Tony H on 22 February 2015, 14:02:13
Yes zirk heater set at maximum
Post by: sjc on 22 February 2015, 14:20:41
What MY?
On the pre-facelift climate, there is a fan built into the control unit to sample the air temp from the cabin and adjust as required.  If the fan fails or gets gummed up with fluff/dust then you get the problem you have.  Easy way to check is to put a small piece of tissue paper over the intake (cut-outs above the centre 2 controls) and if it doesn't stay put with the small amount of suction then the fan ain't turning.
Have you done the 'reset flaps' procedure?
Facelift may be a completely different setup.
Post by: Andy H on 22 February 2015, 15:03:37
TIA
Tony
Probably a faulty outside temperature sensor. What temperature is displayed on the MID?
Post by: Andy B on 22 February 2015, 15:06:25
.... Probably a faulty outside temperature sensor. What temperature is displayed on the MID?
that assumes Tony's car is a facelift  :-\
Post by: TheBoy on 22 February 2015, 15:06:51
What MY?
FL is similar
Post by: Tony H on 22 February 2015, 15:59:52
TIA
Tony
Thats a good point the outside temp sensor is displaying 44 degrees I think its telling fibs cos it's rather freezing up here. By the way my miggy is a facelift
Post by: Andy B on 22 February 2015, 16:03:05
.... By the way my miggy is a facelift
It's that long since I've seen you I couldn't remember  ;)
Post by: Andy H on 22 February 2015, 16:07:31
TIA
Tony
That's the problem identified then.
A new sensor is cheap and easy to fit which may fix the problem. If it doesn't then you need to look for corroded connectors and damaged wiring in the loom the sensor shares with the front foglights.
Post by: sjc on 22 February 2015, 16:16:49
I've got a sensor here, can double-check it's working.
Post by: Tony H on 24 February 2015, 19:07:01
Yeah not been able to make any meets for a while hope to catch you at the next one :y
Post by: Andy B on 24 February 2015, 19:51:18
Like wise ...... see you then  :y
I'll park my Merc in a corner out of the way  ;) ;)
