Chat Area => General Car Chat => Topic started by: Field Marshal Dr. Opti on 07 March 2015, 14:30:11
Title: 33,000 mile front discs.
Post by: Field Marshal Dr. Opti on 07 March 2015, 14:30:11
Maybe I changed them too early. :)
(http://i970.photobucket.com/albums/ae183/janbowles/discs1.jpg)
(http://i970.photobucket.com/albums/ae183/janbowles/disc2.jpg)
(http://i970.photobucket.com/albums/ae183/janbowles/disc4.jpg)
(http://i970.photobucket.com/albums/ae183/janbowles/disc5.jpg)
(http://i970.photobucket.com/albums/ae183/janbowles/disc3.jpg)
(http://i970.photobucket.com/albums/ae183/janbowles/disc6.jpg)
Title: Re: 33,000 mile front discs.
Post by: tigers_gonads on 07 March 2015, 14:36:44
Could have re skimmed them for a tenner and got another 30K out of them  ;D
Post by: Field Marshal Dr. Opti on 07 March 2015, 14:41:11
Tempting.......Mr gonads. ;)
Post by: chrisgixer on 07 March 2015, 15:08:49
Christ almighty. Take a set of brakes and remove half the already appalling performance.  :o
That must of been shocking to drive....?
Post by: 05omegav6 on 07 March 2015, 15:34:01
That must of been shocking to stop....?
Fixed :o
Post by: Field Marshal Dr. Opti on 07 March 2015, 16:03:31
Yes.....it was scary at times. Brakes feel so much better now. :y
Post by: Field Marshal Dr. Opti on 07 March 2015, 16:04:32
Fixed :o
Yep.....no need for a high fibre cereal to keep me regular. ;D ;D
Post by: Field Marshal Dr. Opti on 07 March 2015, 16:05:51
The pads have a large 'overhang' in them.
Post by: EMD on 07 March 2015, 19:04:05
Loads of life left in them  :y
Post by: chrisgixer on 07 March 2015, 19:37:35
Normal. Although I'm sure you've seen similar pics on here. And possibly not that severe ;D
Post by: Andy H on 07 March 2015, 21:47:30
Ground away by the build up of iron oxide - a cheap but effective abrasive.
How did the discs get so rusty in the first place? do you park it in the sea?
Post by: Andy B on 07 March 2015, 21:52:50
they look similar to those removed from my car a few years ago ......can't remember the mileage - but it was a lot more than 30k
(http://i84.photobucket.com/albums/k17/Tiff4327/Omega/S73F0901-1.jpg) (http://s84.photobucket.com/user/Tiff4327/media/Omega/S73F0901-1.jpg.html)
Post by: chrisgixer on 07 March 2015, 21:56:49
I don't care what that eejit admin says. Paint them.
Vastly reduces the amount of rust, which kills them long before the wear depth and the minimum thickness of the disk is reached.
Post by: Andy H on 07 March 2015, 22:27:01
The paint process you found a few months ago puts a very thin layer of zinc all over discs at the factory. The coating on the swept area gets scrubbed off quickly on first use (so doesn't put too much contamination on the brake pads) but the remaining coating provides a long lasting sacrificial anode.
If I had a choice I would buy zinc coated discs but there is no way I would slap paint on them.
Post by: JamesV6CDX on 07 March 2015, 22:28:53
What sort of paint would you use Chris?
Good to see you around mate :y
Post by: chrisgixer on 07 March 2015, 23:03:40
De grease, then Heat resistant. There are rattle cans suitable. It won't last forever obviously, but delays the start of the rust process long enough to get the best out of them.
Obviously if the discs are already treated/painted with a rust deterant, like my 360mm phaeton discs for example  8) , then there's no need to bother. ....hopefully. Time will tell. :)
Gm discs are not treated. Others may well be, I haven't looked into omega ones.
Post by: TheBoy on 08 March 2015, 10:17:38
That is quite normal (though not to that extent!) on Omegas.  The inside face seems to corrode in from the outer edge. Not sure if that is time related, or mileage related - suspect the former. What age are they?
I know chrisgixer painted the edge of his with caliper paint to stop the corrosion setting in, and recall he said it helped. Might be worth double checking with him?  But this needs to be done before the rust sets in.  Not tried it myself, but probably will for the next set I have to fit.
//Edit - should read entire thread first ;D
Post by: Field Marshal Dr. Opti on 08 March 2015, 14:00:22
New discs are Pagid. Are they 'treated'?
Post by: Nick W on 08 March 2015, 14:06:45
Usually, yes. The rears that have been on my  car for the last 3 years are just starting to look a little 'dirty.'
I can't imagine how painting the unswept areas would prevent the sort of wear shown, as that's down to the pad and caliper. Mostly the caliper in my experience.
Post by: chrisgixer on 08 March 2015, 14:23:13
It's rust eating in from the edges. Add in heat, and expansion and contraction and the surface cracks off towards the middle as in the pic. Esp when the pad rusts to the swept area after a lay up in the cold. Nothing to do about that obviously but cracks and lines apear where the pad leaves a rust mark. Then chunks start falling off and the brakes vibrate and loose power.
The obvious pointer is the 10mm line that creaps in from the inboard face.
Post by: Andy H on 08 March 2015, 17:50:05
The rust is very abrasive, it wears away the pad instead of the pad  sweeping the rust off as you might expect. That is why the rust band grows because the edge of it eats away at the remaining good brake pad.
Zinc coatings (including hot dip galvanising) work by sacrificial galvanic action.  The swept area will be protected from corrosion by zinc deposited elsewhere on the disc not by a protective coating isolating the swept area from the atmosphere.
