Chat Area => General Car Chat => Topic started by: pauls on 09 March 2015, 11:08:55
Title: part numbers wanted
Post by: pauls on 09 March 2015, 11:08:55
Just been over to my local dealers and spoke to what i could only say is if he found his brain cell he would be dangerous >:( >:(
Can somebody help I need the part number for the top radiator thermostat also the red radiator drain plug.
cheers
Title: Re: part numbers wanted
Post by: Nick W on 09 March 2015, 11:19:36
A complete OE thermostat is £20 delivered from various suppliers. Mine came from vauxworld and is clearly OE, as whoever was responsible for grinding the GM markings off it wasn't very conscientious.
Post by: 05omegav6 on 09 March 2015, 12:01:24
I believe Paul is after the upper of the two thermoswitches on the battery end of the radiator :y
Certainly whichever one controls the front fans :-\
Post by: pauls on 09 March 2015, 12:22:15
That be the one :y
Post by: PhilRich on 09 March 2015, 14:11:23
If the V6 & 4 pot have the same rad sensor then the part No. is 12992783, if not, then take no notice of me as i'm getting worse by the day! ;D :y
Post by: TheBoy on 09 March 2015, 17:54:34
They vary, so will need the ident off it :(
Post by: omegod on 09 March 2015, 18:30:02
Halfords do a little set of replacement O rings that sort the drain plug
Post by: andyc on 09 March 2015, 23:42:57
Rad Fan Switch, ID XA 90458540
Rad Fan Switch, ID WM 90376209
Rad Drain Plug, 52463060
Rad Drain Plug Washer, 52462868
Cheers
Andy
Post by: pauls on 10 March 2015, 07:33:38
Cheers Andyc :y
