Omega Help Area => Omega General Help => Topic started by: Webby the Bear on 03 May 2015, 17:45:10
Title: Vac box near pollen filter: anyone got a pic?
Post by: Webby the Bear on 03 May 2015, 17:45:10
Had a quick look for this as I just want to check its in working order. I can follow the lines coming in to it but even with pollen filter out it seems to be a lot further back than I can get to.
To be fair I did only have a two minute check whilst under the influence lol but any info on how to get to it would be, well... Immense  :y
Title: Re: Vac box near pollen filter: anyone got a pic?
Post by: flyer 0712 on 03 May 2015, 22:29:08
Yep it is there...need very small hands to make sure of pipe connections,,but normaly ok... :y
Post by: Webby the Bear on 04 May 2015, 11:45:03
Yeah I thought that may be the case. I'll have another go at getting my big bear paw in there  ::) :y
Approx how far back is the box? I presume it's bolted to the bulkheads?
Post by: chrisgixer on 04 May 2015, 11:46:44
May get a pic today at the Wycombe meet as there's scuttle off work going on.
Post by: Webby the Bear on 04 May 2015, 12:20:03
Legend Chris thanks very much  :y
Post by: chrisgixer on 04 May 2015, 18:23:50
Sorry webby. Missed the scuttle work. :(
Post by: YZ250 on 04 May 2015, 18:30:14
My fault, I did remember as well but thought it was the position that was required. If you remove the short end of the scuttle it is clearly visible fixed behind the pollen filter plastics.  :y
Have a look at this link. 7th photo down clearly shows the vac box fitted to the back of the pollen filter housing.  :y
http://www.omegaowners.com/forum/index.php?topic=90650.msg1155601#msg1155601
Post by: YZ250 on 04 May 2015, 18:47:13
There's an echo in here, I ran out of edit time.  ;D Right, I'll try again.  :y
You won't see it by just lifting the flap.
Have a look at this link. 7th and 17th photo down clearly shows the vac box fitted to the back of the pollen filter housing.  :y
Post by: Webby the Bear on 04 May 2015, 18:58:14
legends cheers boys, ill get rid of the short scuttle cover  :y
hope you had a good time at the meet  :y
