Omega Help Area => Omega General Help => Topic started by: terry paget on 11 May 2015, 19:45:09
Title: Need spare key. Car pass and VX supply?
Post by: terry paget on 11 May 2015, 19:45:09
Bought a used Omega on Sunday. It came with only one key and no car pass. Is there any other route other than Vx dealer, buy car pass and new key?
Title: Re: Need spare key. Car pass and VX supply?
Post by: Nick W on 11 May 2015, 19:48:18
A decent automotive locksmith will be able to sort all of that for you, for about half the Vx price and while you wait.
It ain't rocket science.
Post by: chrisgixer on 11 May 2015, 20:07:38
Still needs an immobiliser chip though.
Car pass is, naturally, only available from vx. The numbers on which, is needed to programme the immobiliser chip via tech2. Admins here have tech 2 Kev being nearest you. :)
Other than that, as said.
Post by: lesv6 on 12 May 2015, 00:12:50
"A decent automotive locksmith will be able to sort all of that for you, for about half the Vx price and while you wait.
It ain't rocket science."
Including immobiliser chip
Post by: Steve B on 12 May 2015, 00:18:20
Lookng forward to seeing that one  :-\
Post by: terry paget on 12 May 2015, 07:52:12
You infer that I have to order the car pass and key from a Vx dealer, then take the car to him to use his Tech2 to instruct the ECU to accept it. My memory is vague, I thought last time I rang Bellinger Vauxhall with the new car reg. no. and they got me a car pass and a 'basic' key for collection the following Friday. By basic key I mean the key cut with transponder fitted. I do not need the flipper remote locking bit. This did not involve the new car or a Tech2.
Also Bellinger managed to resynchronise an old flipper of mine to the new car, using the Tech2. Was this not the service The Boy was performing at High Wycombe?
Post by: TheBoy on 12 May 2015, 18:05:50
There are 3 parts to an Omega RF "key":
The mechanical blade/key
The transponder (small chip that clips in the horseshoe of post 1998 keys, or lives within the plastic bulk of key for 1996 and 1997 cars), this is needed to start the car
The fob (the bit with the battery in, that clips into the horseshoe on post 1998 cars, and entirely separate unit on the keyring on 1996 and 1997 cars), needed to remotely lock/unlock car, and disable alarm
The mechanical key needs cutting in the usual way. Some keycutters refuse, just find another.
The transponder needs programming to the Immobiliser ECU. This needs a Tech2 (or similar) and the PIN code for the immobiliser (written on carpass)
The Fob needs programming to the CL ECU (Plod and GLS) or ATWS ECU (CD upwards). This needs Tech2 (or similar) and the PIN for the ECU (written on carpass)
None of above applies to 1994 and 1995 cars that use the IR immobiliser/locking.
Post by: chrisgixer on 12 May 2015, 20:34:45
So, as TB says, it needs the numbers from a car pass, to enable programming the chip via tech2, in order to start the car. My point was, a key cutter can not help you with that.
In order.
Get car pass from Vx.
Get a basic key cut with chip. (from a key cutter will do, if not Vx blipper type )
Take key and number to Kevin (or other tech 2)to programme chip and check it all works.
Seemples.
Vx will need to see proof you own the car btw. V5 etc.
Although, clarification as to what year and key type is needed really.
